Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: Is there any support for EPICS for IronPython (or anyone working on it)?
To: EPICS Tech Talk <tech-talk@aps.anl.gov>
Cc: "Skorpenske, Harley David" <skorpenskehd@ornl.gov>
Date: Fri, 12 May 2017 18:44:45 +0000
In follow up to http://www.aps.anl.gov/epics/tech-talk/2016/msg01425.php from last August . . .
The MTS customer referenced was one of the beam lines here at SNS. They are interested in using the IronPython interface included with the new MTS load-frame software to pass parameters to our EPICS beam line control system using PyEpics.
Harley (cc’d here but not on tech-talk) gave it a try . . .
>>> from epics import caget
>>> beampower = caget('RTBT_Diag:BCM25I:Power60')
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "C:\Python27\Lib\site-packages\epics\__init__.py", line 81, in caget
  File "C:\Python27\Lib\site-packages\epics\pv.py", line 39, in get_pv
  File "C:\Python27\Lib\site-packages\epics\ca.py", line 359, in wrapper
  File "C:\Python27\Lib\site-packages\epics\ca.py", line 239, in initialize_libca
AttributeError: 'ArrayType' object has no attribute 'in_dll'
cannot connect to RTBT_Diag:BCM25I:Power60
The first call to pyepics from IronPython always gives the AttributeError; all subsequent calls give “cannot connect”.
Regular C Python 2.7 was used to install PyEpics using the installer exe. On the same host, it can successfully connect and read the same PV so not likely to be a network or access permission issue.
Tested with . . .
IronPython 2.7.7 (2.7.7.0) on .NET 4.0.30319.42000
32-bit and 64-bit
Any suggestions?
Steven Hartman
hartmansm@ornl.gov
Re: Is there any support for EPICS for IronPython (or anyone working on it)? Matt Newville
Prev: OPC UA EPICS device support license Thomas, Patrick
Next: Re: Is there any support for EPICS for IronPython (or anyone working on it)? Matt Newville
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: Re: OPC UA EPICS device support license Jack
ANJ, 18 May 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
