>> What would be the cause?
The root cause is that your mgmt webapp is having trouble communicating with the engine webapp. You can look into this a bit more by trying the URL yourself from the command line using curl. Also, looking in the engine's logs will help. If you suspect the
engine is non-responsive, you can get a stack trace and then see what the threads are doing. Is there anything in the engine's logs? Does top show anything on the engine?
Exception getting contents of internal URL http://10.2.0.23:17666/engine/bpl/getVersion
org.apache.http.conn.HttpHostConnectException: Connect to 10.2.0.23:17666 [/10.2.0.23] failed: Connection refused
>> Another thing I had to restart the entire engine from the sampleStartup.sh script
>> Is there a simpler way to start a single appliance only?
I suspect you mean "I had to restart the entire appliance" and "Is
there a simpler way to start a single component only"
Ultimately, these are all Tomcat containers; so you should be able to stop/start them any of the methods available for stopping/starting Tomcat. I assume you are using jsvc; in which case, stopping a component is simply adding a -stop argument to the jsvc
command like so
-pidfile ${CATALINA_BASE}/pid \
-stop \
org.apache.catalina.startup.Bootstrap
So you could use the sampleStartup as a starting point and then strip out the calls to stopTomcatAtLocation and startTomcatAtLocation to the other components.
Hope that helps.
Murali
