Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: MEDM Close Display
To: Elmer Pensack <pensacke@gmail.com>, <tech-talk@aps.anl.gov>
Date: Fri, 5 May 2017 14:06:45 -0500
If you're running on Linux you can close the active X windows from the
command line using one of the following combinations of commands.
bash:
  $ wmctrl -ic `xprop -root | grep '_NET_ACTIVE_WINDOW(' | cut -d \# -f 2`
tcsh:
  $ wmctrl -ic `xprop -root | grep '_NET_ACTIVE_WINDOW(' | cut -d # -f 2`
It is sometimes useful to get a list of all of the X window IDs:
  $ xprop -root | grep "_NET_CLIENT_LIST(WINDOW)"
The IDs can then be used to get the name of each window:
  $ xprop -id [HEX_ID_GOES_HERE] | grep WM_NAME
There is another program, xdotool, that allows windows to be
repositioned from the command line.  I don't believe it is installed by
default on most Linux systems.  I use xdotool on OS X to work around
bugs in the X server that result in MEDM screens appearing off the
viewable desktop when unlocking the screen.
Kevin
On 5/5/17 12:44 PM, Elmer Pensack wrote:
> Greetings,
> Simple MEDM question.
> Is there a way to close a MEDM display without clicking the x in the top
> right corner (or right-clicking and selecting close)? I'm looking for a
> CLOSE button. I thought a shell command button would a possibility, but
> I'm not sure what to call.
> Thanks!
> Elmer Pensack
MEDM Close Display Elmer Pensack
Prev: Re: MEDM Close Display Elmer Pensack
Next: Re: MEDM Close Display Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: Re: MEDM Close Display Andrew Johnson
Next: areaDetector and ADCore R3-0 released Mark Rivers
ANJ, 05 May 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
