hi,
I am new user of autosave and I have two questions to consult you:
1) My PV value refresh every seconds and I want to record them in one minute.
As for test, I set one minute generate 60 sequence files, and then check up each files the time intervales.
The following lines are segment of my st.cmd file:
save_restoreSet_NumSeqFiles(60) ##//number of sequence files: 60
save_restoreSet_SeqPeriodInSeconds(1) ##// sequence file per second
iocInit
create_monitor_set("auto1.req",1,"P=RSIS:") ##//begin save record per second
however, only 10 files generated (from auto1.sav0 to auto1.sav9 ), and the time intervals of pv value between each file are different (auto1.sav0 and auto1.sav1 are 8 seconds; auto1.sav1 and auto1.sav2 are 12 seconds; auto1.sav2 and auto1.sav3 are 8 seconds.......and
so on.).
I have no idea the limit time invervals that the autosave can record and the limit sequence files number.
2) Can autosave list all my PV value during 60 seconds with timestamp in one single file and how to do ?
Thanks in advanced and any help will be appreciated !
Zhefu
