Hi Andraz
Thank you for the tip, the proxy works now with the QEGui tool.
Now instead of having the AA locally I moved it to another PC to have something similar to what Michael wrote here: https://github.com/epicsdeb/carchivetools/blob/master/README-a2aproxy.md , but in the twisted log all components are returned with localhost instead of that PC's IP, so I modified the appliance.xml on that PC to have the actual IP instead of localhost and it works just fine.
Looking forward for native support for AA on Qt.
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo
-----Original Message-----
Sent: Tuesday, May 02, 2017 7:00 AM
To: Abdalla Ahmad <[email protected]>
Cc: [email protected]; [email protected]
Subject: RE: EpicsQT and Archiver Appliance
Hi Abdalla,
This is how I set up a2aproxy to work with Archiver Appliance (AA) and EpicsQT:
* In order for the a2aproxy to get all of the info it needs to work properly, you have to give it a getApplianceInfo endpoint, so if you have a default AA setup, that should be http://localhost:17665/mgmt/bpl/getApplianceInfo.
* To start the a2aproxy I execute: twistd -n -l <path_to_log_file> a2aproxy -P 8080 -A http://localhost:17665/mgmt/bpl/getApplianceInfo
This will start it in nodaemon mode, output logs into <path_to_log_file> and listen on port 8080 for requests from your EpicsQt client.
* If you have have this up and running successfully, the only thing left to do is to set:
QE_ARCHIVE_LIST=<your_host>:8080/cgi-bin/ArchiveDataServer.cgi on your EpicsQt client host.
You have to use the cgi-bin/ArchiveDataServer.cgi endpoint since a2aproxy is mimicking a standard CA Archiver.
* When you'll be retrieving the data, you can't use the linear mode as it's not supported by a2aproxy, so try raw or plot binning.
Let me know how it goes.
Cheers,
Andraz Pozar | Controls Engineer| Australian Synchrotron
p: (03) 8540 5387 | f: (03) 8540 4200
[email protected] | www.synchrotron.org.au
800 Blackburn Road, Clayton, Victoria 3168
Message: 4
Date: Mon, 1 May 2017 11:48:56 +0000
To: Michael Davidsaver <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Message-ID:
<[email protected]>
Content-Type: text/plain; charset="us-ascii"
Hello Michael
After enabling the '-d' option I get this:
[carchive.util.LimitedSite] DEBUG:carchiveutil build IPv4Address(TCP, 127.0.0.1, 41780) <twisted.web.http.HTTPChannel instance at 0x397d638 [HTTPChannel,0,127.0.0.1] 127.0.0.1 - - [01/May/2017:11:35:02 +0000] "POST /retrieval HTTP/1.1" 404 153 "-" "libmaia/0.2"
Regarding your request for the channel archiver client source, I have included Andrew Starritt one of the EPICS Qt project developers, maybe he can elaborate more on this.
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
www.sesame.org.jo
From: Michael Davidsaver [mailto:[email protected]]
Sent: Thursday, April 27, 2017 4:37 PM
Subject: Re: EpicsQT and Archiver Appliance
On 04/27/2017 02:22 AM, Abdalla Ahmad wrote:
> Hello Michael
> Thank you for the tips, the proxy is now running as you pointed out:
> Twistd -n a2aproxy -P 8888 -A localhost:8888/retrieval
Can you also add '-d' to turn on some extra debug output?
> but I think I missed something on the client side.
> I have EPICS Qt 3.2.4 with Qt 5.6.0 installation on the same server as the AA and I exported QE_ARCHIVE_LIST as "localhost:8888/retrieval but running Archive Status in QEGui tool still gives me:
Do you (or anyone) know where the source for this channel archiver client can be found?
> INFO: Requesting PV name info from http://localhost:8888/retrieval
> ERROR: request failure from http://localhost:8888/retrieval
Does the a2aproxy log include any errors? If the xmlrpc call results in a python exception, then something will be logged.
With debugging enabled you should see a line with 'archiver.names' for every client request.
It is also possible that a2aproxy is returning some xml which violates assumptions of the client code. With xml the obvious candidate would be ordering. a2aproxy builds xml using python dictionaries, which do not have stable/defined iteration ordering, which some xml parsers require.
> Best Regaerds,
> Abdalla.
> Sent: Wednesday, April 26, 2017 4:17 PM
> On 04/26/2017 06:50 AM, Abdalla Ahmad wrote:
>> Dear Michael
>> Can you please elaborate more on installing the proxy you wrote? I'm having difficulties running it on Scientific Linux 7 machine.
>> First I have the requirements (numpy, twisted and protocol-buffer), then I did:
>> python setup.py build
>> sudo python setup.py install
>> After that I ran the command as in the README:
>> twistd -n a2aproxy -P 8888 AA-SERVER-URL:17665
>> And then I get "Wrong number of arguments".
> oops, the README was wrong! '-A' is missing. Now fixed.
> An known working example from nsls2 can be seen in debian/channelarchiver-a2aproxy.default in the source tree.
>> twistd a2aproxy -P 8889 -A
>> http://capp01.cs.nsls2.local:17665/mgmt/bpl/getApplianceInfo -d
>> Running "twistd a2aproxy" gives an error like "No module named EPICSEvent_pb2". Also when reordering the arguments it does not recognize the "-n" option.
> twistd is picky about ordering of arguments as these are parsed by
> different code. Arguments before the application name ('a2aproxy' in
> this case) are for twisted itself (run 'twistd -h'). The remaining
> arguments are for the application. (run 'twistd a2aproxy -h')
> Switch to some other directory and retry.
> By default python searches the current directory before /usr/local. I would guess that, after installation, your shell is still in the source directory, so 'import carchive' finds the copy in the source tree which doesn't contain the generated files.
>> python -c 'import carchive; print carchive.__file__'
> Will show the path of the module which was imported.
Tech-talk mailing list [email protected] https://mailman.aps.anl.gov/mailman/listinfo/tech-talk
End of Tech-talk Digest, Vol 11, Issue 157
- RE: EpicsQT and Archiver Appliance Andraz Pozar
Question about autosave ? lzf neu
<2017>
CA gatway runs away when zero length PV name in UDP search request Shuei YAMADA
<2017>
