1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: asyn or caput rate limits?
To: "Brown, Garth" <[email protected]>, "'[email protected]'" <[email protected]>
Cc: "Gang Huang \([email protected]\)" <[email protected]>, "Carlos Serrano \([email protected]\)" <[email protected]>, "Larry Doolittle \([email protected]\)" <[email protected]>, "Ratti, Alessandro G" <[email protected]>, "Vamsi Vytla \([email protected]\)" <[email protected]>
Date: Sun, 30 Apr 2017 18:27:49 -0400
On 04/29/2017 05:54 PM, Brown, Garth wrote:
>>>> for tag in range(2, 130):
> ...     print tag
> ...     epics.caput('RFS2:B15:SHELL_0_DSP_TAG_W', tag)
This client design  will *always* have a risk of dropping put values.
In fact this is part of the design of Channel Access, asyn, and the
EPICS database to avoid unbounded queue sizes.  If you can't tolerate
lose of put values then I think you'll need to address rate limiting at
the client/sender end.
Simply adding 'wait=True' to caput() will ensure that the client will
not send put requests faster than the server/IOC can process them.  This
will work the same with and without ASYN_CANBLOCK on the server end.
http://cars9.uchicago.edu/software/python/pyepics3/overview.html#epics.caput
http://cars9.uchicago.edu/software/python/pyepics3/pv.html#put-with-wait-put-callbacks-and-put-complete
asyn or caput rate limits? Brown, Garth
Prev: RE: asyn or caput rate limits? Brown, Garth
Next: EPICSQt 3.4.2 release Andrew C. Starritt
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
