1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: CA gatway runs away when zero length PV name in UDP search request
Cc: [email protected]
Date: Fri, 28 Apr 2017 17:02:42 +0900
Dear Kay, dear Andrew,
thank you for your replies. I applied the patch against JCA_PV.java in
our CSS 4.4.x and will we what will happen next time.
I also checked the OPI file under the question and found no empty PV
name (or ""), no typo nor empty macto substitusion.
By the way I'm still failing to reproduce the problem by:
- using empty PV name in Text Update
- substituting macro with empty string
- entering empty PV name in EPICS PV tree
- using empty PV name in databrowser2
best regards,
Shuei
                 Shuei Yamada,
                 High Energy Accelerator Research Organization (KEK)
                 mailto:[email protected]
CA gatway runs away when zero length PV name in UDP search request Shuei YAMADA
Re: CA gatway runs away when zero length PV name in UDP search request Andrew Johnson
Prev: CSS perspective from OPI [email protected]
Next: RE: CSS perspective from OPI will.rogers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: CA gatway runs away when zero length PV name in UDP search request Andrew Johnson
Next: Re: CA gatway runs away when zero length PV name in UDP search request Anton Derbenev
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
