1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: Control System Studio: Final value can't be of type PVANTNDArray
To: "Heinz P. Junkes" <[email protected]>
Cc: "[email protected] \([email protected]\)" <[email protected]>
Date: Wed, 26 Apr 2017 16:16:10 -0400
Hi Heinz,
It should work if you use a formula:
=ndArray('pva://testNDArray')
Bruno
On Wed, Apr 26, 2017 at 5:25 AM, Heinz P. Junkes <[email protected]> wrote:
Sorry, asking always the same...
Running Control System Studio 4.3.3 with plugin n-dimensional array installed.
If I am doing a probe of pva://testNDArray, I get
java.lang.RuntimeException: Final value can't be of type PVANTNDArray.
    at org.diirt.datasource.NotificationSupport.findNotificationSupportFor(NotificationSupport.java:60)
    at org.diirt.datasource.PVDirector.notifyPv(PVDirector.java:286)
    at org.diirt.datasource.PVDirector.access$1(PVDirector.java:271)
    at org.diirt.datasource.PVDirector$1.desiredRateEvent(PVDirector.java:403)
    at org.diirt.datasource.SourceDesiredRateDecoupler.sendDesiredRateEvent(SourceDesiredRateDecoupler.java:168)
    at org.diirt.datasource.PassiveScanDecoupler$1.run(PassiveScanDecoupler.java:52)
    at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
    at java.util.concurrent.FutureTask.run(FutureTask.java:266)
    at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)
    at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)
    at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
    at java.lang.Thread.run(Thread.java:748)
Re: Control System Studio: Final value can't be of type PVANTNDArray Heinz Junkes
Control System Studio: Final value can't be of type PVANTNDArray Heinz P. Junkes
Prev: Re: caRepeater not found when starting ioc under procServ Maren Purves
Next: Re: caRepeater not found when starting ioc under procServ Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Control System Studio: Final value can't be of type PVANTNDArray Heinz P. Junkes
Next: Re: Control System Studio: Final value can't be of type PVANTNDArray Heinz Junkes
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
