Maybe using full path to the caRepeater would solve it?
Otherwise, I think using a config file that specifies the path and sourcing it in initd script might do the trick, too. As far as I know that is what any other initd script would do.
Thanks, Hinko Hello,
When I start my soft IOC under procserv using the procserv-initd script, the IOC reports that the caRepeater executable can't be located. This is surely because the PATH variable is not set right in this case.
The question is how (or where) do you have to set the PATH variable for processes running under procServ using the procserv-initd script?
Thanks...
-- Mike Westfall
Control Systems Software Engineer
.. the more I see the less I believe.., AE AoR
- Re: caRepeater not found when starting ioc under procServ Bruce Hill
- caRepeater not found when starting ioc under procServ Michael Westfall
Re: EpicsQT and Archiver Appliance Michael Davidsaver
<2017>
<2017>
