On 04/24/2017 10:21 AM, Michael Davidsaver wrote:
> On 04/24/2017 05:27 AM, Abdalla Ahmad wrote:
>> Hi
>> I used a single machine install for testing the archiver appliance as a
>> proof-of-concept on a local machine. I added 2 PVs to the system using
>> the management console, the status goes from "initial sampling" to
>> "Appliance assigned" and it just stops here where it should go to "Being
>> archived". Why the appliance is not archiving the PVs?
> I suspect that the policy hook script is rejecting these PVs for some
> reason. Have you customized this script at all?
FYI. to keep track of this policy decisions I added logging to the
policy script. This way PVs accept/reject (and script errors) are kept.
> # -*- coding: utf-8 -*-
> import logging
> from logging import handlers
> def _log():
> L = logging.getLogger('policy')
> if len(L.handlers)>5:
> return L
> F = logging.Formatter('%(asctime)s\t%(levelname)s\t%(message)s')
> H = handlers.RotatingFileHandler('/var/lib/tomcat7-archappl/engine/logs/appl-policy.log',
> maxBytes=1024*1024*10, backupCount=10)
> H.setFormatter(F)
> L.addHandler(H)
> L.setLevel(logging.DEBUG)
> L.propagate = False
> return L
> _log = _log()
> def getPolicyList():
> return {
> 'default':'Keep all data',
> 'week':'Keep past 7 days',
> 'fast':'High update rate',
> _level_alarm = ['HIHI','HIGH','LOW','LOLO','LOPR','HOPR','ADEL','EGU']
> _level_setting= ['DRVH','DRVL']
> _binary = ['ZNAM', 'ONAM']
> _rec_files = {
> 'calc':_level_alarm,
> 'calcout':_level_alarm,
> 'ai':_level_alarm,
> 'ao':_level_alarm+_level_setting,
> 'longin':_level_alarm,
> 'longout':_level_alarm+_level_setting,
> 'bi':_binary,
> 'bo':_binary,
> _all_fields = list(set(_level_alarm+_level_setting+_binary))
> def getFieldsArchivedAsPartOfStream():
> return _all_fields
> _default_stores = [
> 'pb://localhost?name=STS&rootFolder=${ARCHAPPL_SHORT_TERM_FOLDER}&partitionGranularity=PARTITION_HOUR&consolidateOnShutdown=true',
> 'pb://localhost?name=MTS&rootFolder=${ARCHAPPL_MEDIUM_TERM_FOLDER}&partitionGranularity=PARTITION_DAY&hold=8&gather=1',
> 'pb://localhost?name=LTS&rootFolder=${ARCHAPPL_LONG_TERM_FOLDER}&partitionGranularity=PARTITION_YEAR',
> _week_stores = [
> 'blackhole://localhost',
> # Inputs
> # info['pvName']
> # info['dbrtype'] - DBR type
> # info['eventRate'] - monitor updates per second
> # info['storageRate'] - bytes per second
> # info['aliasName'] -
> # info['policyName'] -
> # info['RTYP'] - Record type name (ie DBR_CLASS_NAME)
> # Outputs
> # D['samplingPeriod'] -
> # D['samplingMethod'] - 'MONITOR' or 'SCAN' or 'DONT_ARCHIVE'
> # D['policyName'] -
> # D['dataStores'] -
> # D['archiveFields'] -
> def determinePolicy(info):
> try:
> return _determinePolicy(info)
> except:
> _log.exception('Failure in _determinePolicy')
> return {'samplingMethod':'DONT_ARCHIVE'}
> def _determinePolicy(info):
> D = {
> 'samplingPeriod':min(1.0, 1.0/(info['eventRate']*1.5)),
> 'samplingMethod':'MONITOR',
> 'policyName': info.get('policyName', 'default'),
> 'dataStores': _default_stores,
> 'archiveFields':_rec_files.get(info.get('RTYP',''), [])
> if D['policyName']=='week':
> D['dataStores'] = _week_stores
> wf = info.get('elementCount',1)>1
> #wf = info.get('RTYP','') in ['waveform','aai','aao','aCalcout','aSub','histogram']
> # 2 Hz max for our 1Hz machine, use 'fast' if need faster:
> thresshold = 0.22 if wf else 2.2
> # This is reverted:
> #thresshold = 10.50#limit to 10 Hz for both waveform and scalar records
> if info['eventRate']>thresshold and D['policyName'] not in ['fast', 'week']:
> D['samplingMethod'] = 'DONT_ARCHIVE'
> _log.warn('Refuse to log fast %s %s', info['pvName'], info)
> return D
> else:
> _log.info('Default log %s %s', info['pvName'], info)
> D['policyName'] = 'default'
> return D
- EPICS Archiver Appliance does not transfer PVs to "Being archived" Abdalla Ahmad
- Re: EPICS Archiver Appliance does not transfer PVs to "Being archived" Michael Davidsaver
Re: EPICS Archiver Appliance does not transfer PVs to "Being archived" Wang, Lin
Re: Data types in monitor function Andrew Johnson
<2017>
<2017>
