1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: CSS binary color text
To: Miguel <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 21 Apr 2017 08:11:20 +0000
Hi Miguel,
You can change the value of almost any attribute of a CSS widget. There are predefined attributes listed in the Rules property that can change the behavior of a widget based on the value of a PV. The screen shot below shows how to define a foreground color rule based off a PV to be green when value is 1, else turn red.
There appears to be no easy way to set the Off/On Label properties from the DB records ZNAM/ONAM fields. In (edm), there is a Label property that allows one to set the label value to (PV State or Literal).  I made a request on github for this option in BOY.  https://github.com/ControlSystemStudio/cs-studio/issues/2189
Cheers,
-Tim Southern
[email protected]
From: <[email protected]> on behalf of Miguel <[email protected]>
Date: Thursday, April 20, 2017 at 10:44 AM
Subject: Re: Fwd: CSS binary color text
I also need to click over it to change the state.
The only way i have so far is in fact to use the Image boolean button. I set the one severity field (OSV) to major .Then set in CSS the foreground to green and checked the ForeColor Alarm Sensitive to yes.
But I am still not able to automatically use the ONAME and ZNAME fields in CSS so I have to manually set the ON and OFF label.
Thanks
On 18-04-2017 11:35, Luca Cavalli wrote:
Hi Miguel,
if you need to display only a text label you can use a Text Update widget with the transparent flag set, plus (as already suggested) a rule to change foreground color upon PV value.
Cheers,
Luca
On Fri, 2017-04-14 at 19:15 +0100, Miguel wrote:
Hello,
I would like to do two things with my bo records in CSS.
1. Have a text that is according to the ONAM and ZNAM pv fields.
2. That this text is green in case of on and red othwerwise
I only manage to do something similiat with an image boolean button
(with no image and ON OFF predefined text)
Thanks
<< Le informazioni contenute in questo messaggio di posta elettronica e relativi allegati sono riservate e confidenziali e ne è vietata la diffusione in qualunque modo eseguita. Qualora Lei non fosse la persona a cui il presente messaggio è destinato, La invitiamo ad eliminarlo e a darcene gentile comunicazione. Quanto precede ai fini del rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196, sulla tutela dei dati personali >>
<< This e-mail is confidential and may well also be legally privileged. If you have received it in error, you are on notice of its status. Please notify us immediately by reply e-mail and then delete this message from your system. Please do not copy it or use it for any purposes, or disclose its contents to any other person: to do so could be a breach of confidence. Thank you for your co-operation. Please contact our IT Helpdesk on +3902380481 or email [email protected] if you need assistance >>
Re: CSS binary color text Luca Cavalli
Re: CSS binary color text Miguel
Prev: RE: Bandwidth limits in asyn Mark Rivers
Next: Re: CSS binary color text Luca Cavalli
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: Fwd: CSS binary color text Miguel
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
