1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: runtime problem
To: Mark Rivers <[email protected]>, 'Michael Davidsaver' <[email protected]>, Pierrick Hanlet <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 19 Apr 2017 16:52:37 +0000
This assumes that the problem Michael was referring to was with the library files, not dbd files.  If the problem is dbd files then of course static build won't help.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: Wednesday, April 19, 2017 10:34 AM
To: 'Michael Davidsaver'; Pierrick Hanlet; [email protected]
Another way to quickly check if Michael's hypothesis is correct is to change your IOC application CONFIG_SITE file to have STATIC_BUILD=YES.   That guarantees that the EPICS build-time and run-time libraries are identical.  If the problem goes away then you probably have a problem with conflicting .so files.  Check your LD_LIBRARY_PATH environment variable.
From: [email protected] [mailto:[email protected]] On Behalf Of Michael Davidsaver
Sent: Wednesday, April 19, 2017 9:50 AM
To: Pierrick Hanlet; [email protected]
Subject: Re: runtime problem
Hi Pierrick,
> concludes with Michael Davidsaver stating:
> "*I've hit this it was because I accidentally loaded a .dbd from an
> older version of epics base*"
> However, I don't believe that's what I've done wrong.
I've not seen this assertion fail in any other circumstance since I
added it.
The specific condition being detected is that the number of fields in
some recordtype is different between the runtime and buildtime definitions.
I suspect that, without intending to, you have epics modules in the
standard search paths (eg. /usr/local), or in your environment (eg. PATH
or LIBRARY_PATH), or perhaps some includes in configure/RELEASE.
I would suggest that you retry your builds in a completely clean
environment.  checkout/untar source into a fresh OS install (a VM would
be a quick way to do this).
Michael
On 04/19/2017 09:31 AM, Pierrick Hanlet wrote:
> Hello,
> I'm using base 3.14.12.3 with SL7.3. I've recently attempted to use
> another version of base, so I'm switching back
> to something that previously worked for me.  When reverting to the older
> version, I first rebuilt all of my support
> modules (asyn, etc.) using the 3.14.12.3 base. Then I rebuilt my IOC.  I
> got no errors, however, when I run, I get:
> *dbLoadDatabase "dbd/TestCryo.dbd"**
> **TestCryo_registerRecordDeviceDriver pdbbase**
> **A call to 'assert(prt->no_fields == 122)'**
> **    by thread '_main_' failed in ../O.Common/asynRecord.h line 426.**
> **EPICS Release EPICS R3.14.12.3 $Date: Mon 2012-12-17 14:11:47 -0600$.**
> **Local time is 2017-04-19 13:30:21.552933101 BST**
> **Please E-mail this message to the author or to [email protected]**
> **Calling epicsThreadSuspendSelf()**
> I followed the tech-talk thread
> http://www.aps.anl.gov/epics/tech-talk/2016/msg01042.php which
> Thanks,
> Pierrick
> "Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
> _______________________________________________________________
> Pierrick Hanlet
> IIT/Fermilab
> +44-(0)1235-44-5550 (RAL)
> +1-630-840-5555 (FNAL)
> +1-312-567-5745 (IIT)
> +1-630-888-0185/+44-(0)79-48-860-197 (US/UK mobile)
runtime problem Pierrick Hanlet
Re: runtime problem Michael Davidsaver
RE: runtime problem Mark Rivers
Prev: RE: runtime problem Mark Rivers
Next: EPICS V4 Windows build warning messages. Mark S. Engbretson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Next: support for Cryomech CP950 compressor (part of PT405 cryorefrigerator) arvinder.palaha
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
