This is a camera we are building. I can propose EPICS Version 4 for new systems, although we also have a legacy system that presently uses 3.15.4, but that could likely be upgraded.
The system receives commands over a socket. The EPICS implementation uses Stream Device to send commands and receive responses.
Iain.
> -----Original Message-----
> From: Mark S. Engbretson [mailto:[email protected]]
> Sent: Tuesday, April 11, 2017 5:19 PM
> To: Iain Marcuson <[email protected]>
> Subject: RE: Writing Area Detector Monitor
> Are you building this ? "cause if you are, you could certainly built low level
> support into the actual hardware that already "talks" Area detector.
> EPICS Version 4 and Area Detector R2-6 supports the area of easily moving
> NDArrays back and forth between hardware.
> How do you talk or do anything with it NOW?
- Writing Area Detector Monitor Iain Marcuson
RE: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays Mark Rivers
RE: Writing Area Detector Monitor Iain Marcuson
<2017>
RE: Writing Area Detector Monitor Mark Rivers
piezosystem jena Hu, Yong
<2017>
