1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: Writing Area Detector Monitor
To: 'Iain Marcuson' <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 11 Apr 2017 21:15:51 +0000
Hi Iain,
The drivers which directly receive images over the network are ADPSL, ADPixirad,  ADMerlin,  and ADMythen.
Many other drivers receive images over the network, but they do this through a vendor API (e.g. ADProsilica, aravisGigE, ADPointGrey, etc.).
If you want to create a driver which works like other areaDetector drivers you should not use StreamDevice for the command/response, you should do it through the driver itself.  Your driver will receive a call each time the user changes things like exposure time, acquire start/stop, frame binning, etc.  You can talk to the device from your driver using the asynIPPort driver and the asynOctetSyncIO interface. All of the drivers I listed above do that so you can see how to do it.
-----Original Message-----
Sent: Tuesday, April 11, 2017 3:54 PM
To: Mark Rivers; [email protected]
> Do you mean that you have a device that sends images over a network port,
> and you would like to create an areaDetector driver to receive those images?
> The driver would convert the images into NDArrays in an EPICS IOC, and thus
> be able to use the areaDetector plugins for file saving, image processing, and
> sending images to EPICS Channel Access clients, etc.?
The device would send images over a network port, and we would be looking to convert them into NDArrays as you describe.
> If this is what you want to do then you can use one of the existing
> areaDetector drivers as a model.  Those create a complete application to
> control and read data from a specific type of camera or detector.
> Can you describe your device a bit more, so I know which existing driver to
> recommend as a starting point?  Can you control the device from your driver
> (exposure time, start/stop, etc.)?  If so are those ASCII commands?  Is it
> TCP/IP or some other protocol?  Is the image data in binary?
The device would be controlled via an IOC.  We will likely use Stream Device, which we have used successfully for a similar control scheme.  The commands would be ASCII based.  The image data is in binary, and at present we are looking towards UDP, although we may use TCP.
RE: Writing Area Detector Monitor Iain Marcuson
RE: Writing Area Detector Monitor Mark Rivers
Prev: RE: Writing Area Detector Monitor Iain Marcuson
Next: piezosystem jena Hu, Yong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Next: RE: Writing Area Detector Monitor Iain Marcuson
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
