> Do you mean that you have a device that sends images over a network port,
> and you would like to create an areaDetector driver to receive those images?
> The driver would convert the images into NDArrays in an EPICS IOC, and thus
> be able to use the areaDetector plugins for file saving, image processing, and
> sending images to EPICS Channel Access clients, etc.?
The device would send images over a network port, and we would be looking to convert them into NDArrays as you describe.
> If this is what you want to do then you can use one of the existing
> areaDetector drivers as a model. Those create a complete application to
> control and read data from a specific type of camera or detector.
> Can you describe your device a bit more, so I know which existing driver to
> recommend as a starting point? Can you control the device from your driver
> (exposure time, start/stop, etc.)? If so are those ASCII commands? Is it
> TCP/IP or some other protocol? Is the image data in binary?
The device would be controlled via an IOC. We will likely use Stream Device, which we have used successfully for a similar control scheme. The commands would be ASCII based. The image data is in binary, and at present we are looking towards UDP, although we may use TCP.
- RE: Writing Area Detector Monitor Mark Rivers
- Writing Area Detector Monitor Iain Marcuson
<2017>
<2017>
