1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: CA client within Asyn
To: Eric Norum <[email protected]>, Benoit RAT <[email protected]>
Cc: EPICS mailing list <[email protected]>
Date: Tue, 11 Apr 2017 15:51:24 +0000
Hi Benoit,
I second Eric's suggestion to look into using the sequencer.  If you decide, nevertheless, to stay in C code...
makeBaseApp.pl will make several kinds of example applications, including two Channel Access examples.
See the Application Developer's Guide.
I don't know of other /good/ examples (that is, examples that were intended primarily to teach or demonstrate) of doing CA in a thread, but there are several examples:
motorUtil* in the motor module.
recDynLink.c in the sscan module
save_restore.c in the autosave module
All of these modules are on github: https://github.com/epics-modules/
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of Eric Norum [[email protected]]
Sent: Tuesday, April 11, 2017 10:00 AM
To: Benoit RAT
Subject: Re: CA client within Asyn
Have you investigated the EPICS sequencer?
I don’t think I’ve heard of anyone attempting to issue channel access calls from an ASYN thread.
On Apr 11, 2017, at 4:00 AM, Benoit RAT <[email protected]> wrote:
Hi everybody,
Within my Asyn IOC I need sometime to modify some PV from other IOC.
I did try to do this using the .db but the task was too complex and I am now trying to setup my own CA client inside Asyn.
As I am using Asyn I have also linked all the callback from CA to the one from Asyn...
This seems to work more or less but I have some problems with the ca_put.
quick resume of what I am doing
--------------- # Part 1 (OK)
At the setup of the IOC I call:
ca_context_create (ca_enable_preemptive_callback);
ca_search_and_connect(pvext_write1->name,&(pvext_write1->chan_id),callback_coHaAr,NULL);
ca_search_and_connect(pvext_write2->name,&(pvext_write2->chan_id),callback_coHaAr,NULL);
ca_search_and_connect(pvext_writeN->name,&(pvext_writeN->chan_id),callback_coHaAr,NULL);
and at the end of the setup I call
ca_flush_io()
This work fine and after some seconds I enter callback_coHaAr() for each of the CA created.
--------------- # Part 2
Then at some point in my code, changes of value my internal PV, I modify external PV.
status=ca_put_callback (DBR_DOUBLE, pvext_write1->chan_id, &(pvext_write1->val.float64),callback_put,pvext_write1);
status=ca_put_callback (DBR_DOUBLE, pvext_write2->chan_id, &(pvext_write2->val.float64),callback_put,pvext_write2);
status=ca_put_callback (DBR_DOUBLE, pvext_writeN->chan_id, &(pvext_writeN->val.float64),callback_put,pvext_writeN);
And after all my writes has been put, I call
ca_flush_io()
And this is when sometime my hook callback_put() is correctly called back (Almost 90% the first time)
 callback_put() > chid:0x949a3a0 usr:0x94c86a8 (status:x1)
But then if I make succesive call, the hook callback_put() might be called back some more time.. and then never
However If I shutdown the remote IOC, all my callback appears
If only one was missing, I get on my epicConsole:
callback_put() > chid:0x95074c8 usr:0x9535860 (status:xc0)
callback_coHaAr() > chid:0x95074c8 op:7 (down)
If 4 were missing:
callback_put() > chid:0x98623f8 usr:0x9890790 (status:xc0)
callback_coHaAr() > chid:0x98623f8 op:7 (down)
Conclusion
I think I am missing something while mixing the epicsThread of asyn and ca, but I really don't know what to try more and I don't find any good examples of ChannelAccess client with thread.
  • Where could I find a good documentation of ca client?
  • Do you think I am missing something?
  • Should I use ca_enable_preemptive_callback...? I am not sure that it is what I need within asyn...
  • Shouid I use something more than flush_io()...?
  • Should I create a thread for this operation and call ca_pend_event() ... I did try to call ca_pend_event(2) for testing but it doesn't seem to correct my problems.
Best,
Benoit RAT LAMY
fix. (+34) 958 285 024
Eric Norum
[email protected]
CA client within Asyn Benoit RAT
Re: CA client within Asyn Eric Norum
Prev: Re: Asyn timeout Hinko Kocevar
Next: RE: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: CA client within Asyn Eric Norum
Next: RE: CA client within Asyn Mark S. Engbretson
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
