Hi all,
I have a problem with the proper configuration of NDDriverStdArrays areaDetector driver.
To test my settings, I have prepared IOC which contains NDDriverStdArrays driver and NDStdArrays plugin.
To caput picture 1236x1236 as a waveform I am using quick python script:
#!/usr/bin/env python
import epics
import numpy as np
import time
while(1):
for x in range(17):
data="">
pv=epics.PV('TEST:ArrayIn')
pv.put(data)
time.sleep(1)
However, I am receiving following error:
2017/04/10 19:46:38.422 NDDriverStdArrays:writeXXXArray: error allocating raw buffer
2017/04/10 19:46:38.422 TEST:ArrayIn devAsynInt16Array::callbackWfOut write error
It looks like my settings are incorrect somewhere. Has anyone encountered this problem before?
Full st.cmd below.
Many thanks,
Marcin
#!../../bin/linux-x86_64/testAD
## You may have to change testAD to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("IOC","ioctestAD")
epicsEnvSet("TOP","/home/eli_sw/work/testAD")
epicsEnvSet("SUPPORT","/home/eli_sw/epics/support")
epicsEnvSet("AREA_DETECTOR","/home/eli_sw/epics/support/areaDetector-2-6")
epicsEnvSet("ADCORE","/home/eli_sw/epics/support/areaDetector-2-6/ADCore")
epicsEnvSet("NDDRIVERSTDARRAYS","/home/eli_sw/epics/support/areaDetector-2-6/NDDriverStdArrays")
epicsEnvSet("ASYN","/home/eli_sw/epics/support/asyn-4-31")
epicsEnvSet("BUSY","/home/eli_sw/epics/support/busy-1-6-1")
epicsEnvSet("EPICS_BASE","/home/eli_sw/epics/R3.15")
cd "/home/eli_sw/work/testAD"
# Prefix for all records
epicsEnvSet("PREFIX", "TEST:")
# The port name for the NDStdArray driver
epicsEnvSet("NDPORT", "NDSA")
# The queue size for all plugins
epicsEnvSet("QSIZE", "3")
# The maximim image width; used to set the maximum size for this driver and for row profiles in the NDPluginStats plugin
epicsEnvSet("XSIZE", "1236")
# The maximim image height; used to set the maximum size for this driver and for column profiles in the NDPluginStats plugin
epicsEnvSet("YSIZE", "1236")
# The maximum number of time series points in the NDPluginStats plugin
epicsEnvSet("NCHANS", "1236")
# The maximum number of frames buffered in the NDPluginCircularBuff plugin
epicsEnvSet("CBUFFS", "500")
# The search path for database files
epicsEnvSet("EPICS_DB_INCLUDE_PATH", "/home/eli_sw/epics/support/areaDetector-2-6/ADCore/db")
# The number of elements in the driver waveform record
epicsEnvSet("NELEMENTS", 1527696)
# The datatype of the waveform record
epicsEnvSet("FTVL", "USHORT")
# The asyn interface waveform record
epicsEnvSet("TYPE", "Int16")
#asynSetMinTimerPeriod(0.001)
epicsEnvSet("EPICS_CA_MAX_ARRAY_BYTES", "10000000")
dbLoadDatabase "dbd/testAD.dbd"
testAD_registerRecordDeviceDriver pdbbase
# Create an NDDriverStdArrays driver
# NDDriverStdArraysConfig(portName, maxBuffers, maxMemory, priority, stackSize)
NDDriverStdArraysConfig("NDSA", 3, 0, 0)
dbLoadRecords("/home/eli_sw/epics/support/areaDetector-2-6/NDDriverStdArrays/db/NDDriverStdArrays.template","P=TEST:,R=,PORT=NDSA,ADDR=0,TIMEOUT=1,NELEMENTS=1527696,TYPE=Int16,FTVL=USHORT")
# Create an NDStdArrays plugins
# NDStdArraysConfigure (const char *portName, int queueSize, int blockingCallbacks,
# const char *NDArrayPort, int NDArrayAddr, size_t maxMemory,
# int priority, int stackSize)
NDStdArraysConfigure("Image1", 3, 0, NDSA, 0)
dbLoadRecords("NDStdArrays.template", "P=TEST:,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=NDSA,TYPE=Int16,FTVL=USHORT,NELEMENTS=1527696")
## Load record instances
#dbLoadRecords("db/xxx.db","user=m")
#asynSetTraceMask $(NDPORT) 0 0xFF
#synSetTraceInfoMask $(NDPORT) 0 0x7
cd "/home/eli_sw/work/testAD/iocBoot/ioctestAD"
iocInit
Starting iocInit
## EPICS R3.15.4 $Date: Fri 2016-05-27 08:54:04 +0200$
## EPICS Base built Mar 28 2017
## Start any sequence programs
#seq sncxxx,"user=m"
dbpf TEST:NDimensions 2
DBR_LONG: 2 0x2
dbpf TEST:Dimensions 1236
DBR_LONG: 1236 0x4d4
dbpf TEST:DataType UInt16
DBR_STRING: "UInt16"
dbpf TEST:ColorMode Mono
DBR_STRING: "Mono"
dbpf TEST:Acquire 1
DBR_STRING: "Acquire"
epics> 2017/04/10 20:10:33.858 NDDriverStdArrays:writeXXXArray: error allocating raw buffer
2017/04/10 20:10:33.858 TEST:ArrayIn devAsynInt16Array::callbackWfOut write error
2017/04/10 20:10:35.009 NDDriverStdArrays:writeXXXArray: error allocating raw buffer
2017/04/10 20:10:35.009 TEST:ArrayIn devAsynInt16Array::callbackWfOut write error
2017/04/10 20:10:36.160 NDDriverStdArrays:writeXXXArray: error allocating raw buffer
2017/04/10 20:10:36.160 TEST:ArrayIn devAsynInt16Array::callbackWfOut write error
2017/04/10 20:10:37.322 NDDriverStdArrays:writeXXXArray: error allocating raw buffer
2017/04/10 20:10:37.323 TEST:ArrayIn devAsynInt16Array::callbackWfOut write error
2017/04/10 20:10:38.521 NDDriverStdArrays:writeXXXArray: error allocating raw buffer
2017/04/10 20:10:38.521 TEST:ArrayIn devAsynInt16Array::callbackWfOut write error
