1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: stringout in softIOC
To: "'[email protected]'" <[email protected]>
Date: Mon, 3 Apr 2017 17:45:33 +0000
Hi
I’m having some issues with stringout records in a softIOC (r3.14.12.5 on Linux).
There are two records (in my contrived example below) the only difference between the two records is in the DOL field, [UBACKLASH] versus [“UBACKLASH”].
soutT1 is loaded and the DOL field is interpreted as a CA_LINK and the OUT field as DB_LINK.
soutT2 has the value of DOL in double quotes, which was my attempt to force it to be a constant. When loaded both DOL and OUT get set to CONSTANT. The DOL value is lost and I don’t understand why OUT does not remain as a DB_LINK.
Al
record(stringout,"soutT1") {
    field(DESC,"string output record")
    field(SCAN,"Passive")
    field(DTYP,"Soft Channel")
    field(VAL,"string")
    field(DOL,"UBACKLASH")
    field(OMSL,"supervisory")
    field(OUT,"param.VAL PP")
record(stringout,"soutT2") {
    field(VAL,"string")
    field(DOL,""UBACKLASH"")
epics> dbpr soutT1,4
DESC: string output record
DOL:CA_LINK UBACKLASH NPP
DTYP: Soft Channel
OMSL: supervisory
OUT:DB_LINK param.VAL PP NMS
OVAL: string
SCAN: Passive
TSEL:CONSTANT
 VAL: string
epics> dbpr soutT2,4
DOL:CONSTANT
DTYP: Soft Channel
OMSL: supervisory
OUT:CONSTANT
OVAL: string
SCAN: Passive
TSEL:CONSTANT
VAL: string
Re: stringout in softIOC Andrew Johnson
Prev: Re: Reset integral pv and store it Ralph Lange
Next: Re: stringout in softIOC Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
