1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: Reset integral pv and store it
To: <[email protected]>
Date: Fri, 31 Mar 2017 10:53:05 -0500
On 03/31/2017 10:05 AM, Kasemir, Kay wrote:
> In C code you can get the
> current time of day in the local time zone, and determine how long you’d
> have to sleep until some specific time. A sequence can ‘delay()’ that
> long and then write to some PV which triggers what you want to happen, or
> post an EPICS event and then have records process on the event.
> You can also call similar C code from a subroutine record, but there you
> can’t sleep/delay. Instead, periodically process the subroutine record
> which for example returns how many more seconds are left to the next
> threshold timestamp and use that in a calcout record to trigger processing
> when the time comes.
It may be easier to do the time manipulation in C code, but it should be
possible to do it purely in the database. An ai record with its DTYP
field set to "Soft Timestamp" returns the number of seconds +
nanoseconds since the EPICS epoch whenever it gets processed. A calcout
record would also be a good idea following this, since it can
conditionally process its output link based on a separate expression.
Alternatively you could create a scan thread with a 24-hour scan period,
although you won't them get to to control when in the day it will
actually process (it will be every 24 hours from the time when the IOC
was started). To do this just copy the file menuScan.dbd from base/dbd
into your IOC's *App/src directory and add a new entry at the top of the
list of periodic scans with the appropriate period in the choice scrint.
If you're using Base-3.15 that's slightly easier than with 3.14 since
your string can be just "24 hours"; in 3.14 the number must be expressed
in seconds.
- Andrew
Re: Reset integral pv and store it Kasemir, Kay
Reset integral pv and store it Miguel
Prev: Re: Reset integral pv and store it Kasemir, Kay
Next: Re: Reset integral pv and store it Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
