Hi John,
Do you know which version of the Base libraries you are using, both for
pcasPy and for the soft IOC? I know we made some changes to the network
interface code recently, and you might find that if you can get pcasPy
to use the latest Base-3.15.5 versions of the libraries the behaviour
might be different. I can't promise it will fix it, but it would be
helpful to know.
One thing I did notice in your ifconfig output, the broadcast inet
address for your container has not been set; configuring that might make
a difference (it's worth trying at least).
- Andrew
On 03/30/2017 11:58 AM, Sparger, John E. wrote:
> Hi,
> If I try to run pcaspy in docker, I get the following error in CAS:
> filename="../../../../src/cas/io/bsdSocket/casDGIntfIO.cc" line number=121
> server isnt attached to a network - unable to continue
> filename="../../../../src/cas/io/bsdSocket/caServerIO.cc" line number=116
> Attempt to set server's IP address/port failed unable to attach explicit
> interface
> filename="../../../../src/cas/generic/caServerI.cc" line number=59
> server isnt attached to a network - CA server internals init unable to
> continue
> terminate called after throwing an instance of 'int'
> I understand that this has something to do with CAS's interface
> detection. However, if I run `softIOC` with the following db
> echo "record(ai,"test_pv") {
> field(VAL,"3")
> }" > test.db
> softIOC -d test.db
> It works fine and I can `caget testpv` from another container without
> issue. This leads me to believe that the plumbing is there but that
> there is some assumption made in how CAS detects broadcast interfaces
> that is not holding true in docker.
> Have you all been able to successfully run pcaspy or cas-based servers
> in docker? Are there some environment variables I can set to help cas along?
> I should note that setting `EPICS_CAS_INTF_ADDR_LIST="localhost"` WILL
> allow pcaspy will run in docker, but then the PVs are not visible
> outside that docker container, so it's not that useful.
> Also for reference, here is what ifconfig returns from inside the container:
> ifconfig
> eth0 Link encap:Ethernet HWaddr 02:42:ac:11:00:02
> inet addr:172.17.0.2 Bcast:0.0.0.0 Mask:255.255.0.0
> inet6 addr: fe80::42:acff:fe11:2/64 Scope:Link
> UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
> RX packets:237 errors:0 dropped:0 overruns:0 frame:0
> TX packets:186 errors:0 dropped:0 overruns:0 carrier:0
> collisions:0 txqueuelen:0
> RX bytes:240235 (234.6 KiB) TX bytes:11013 (10.7 KiB)
> lo Link encap:Local Loopback
> inet addr:127.0.0.1 Mask:255.0.0.0
> inet6 addr: ::1/128 Scope:Host
> UP LOOPBACK RUNNING MTU:65536 Metric:1
> RX packets:3 errors:0 dropped:0 overruns:0 frame:0
> TX packets:3 errors:0 dropped:0 overruns:0 carrier:0
> collisions:0 txqueuelen:1
> RX bytes:208 (208.0 B) TX bytes:208 (208.0 B)
> Thanks for the help,
> John Sparger
- Re: PCAS (using pcaspy) in docker ""server isnt attached to a network" Sparger, John E.
- PCAS (using pcaspy) in docker ""server isnt attached to a network" Sparger, John E.
Re: Question about PV name by using pcaspy Xiaoqiang Wang
TcIoc tyse_ljw
<2017>
<2017>
