Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: Question about PV name by using pcaspy
To: lzf neu <lzfneu@live.com>
Cc: Epics <tech-talk@aps.anl.gov>
Date: Thu, 30 Mar 2017 21:31:05 +0200
Here is a simple example. It monitors a PV ‘catest’ and synchronise its value to `MTEST:PROXY’
from pcaspy import Driver, SimpleServer
from CaChannel import ca, CaChannel
prefix = 'MTEST:'
pvdb = {
    'PROXY': {
class myDriver(Driver):
    def __init__(self):
        Driver.__init__(self)
        self.chan = CaChannel('catest')
        self.chan.searchw()
        self.chan.add_masked_array_event(None, None, None, self.value_callback)
    def value_callback(self, epics_args, user_args):
        self.setParam('PROXY', epics_args['pv_value'])
        self.updatePVs()
if __name__ == '__main__':
    server = SimpleServer()
    server.createPV(prefix, pvdb)
    driver = myDriver()
    while True:
        # process CA transactions
        server.process(0.1)
> On 30 Mar 2017, at 17:45, lzf neu <lzfneu@live.com> wrote:
> Thank you!
> I have a new question to consult you:
> I want to get the return value of caget('some PV name') by writing Pcaspy script. I have no idear what command to use in the script.
> Any suggestions will be appreciated !
> 发件人: Kasemir, Kay <kasemirk@ornl.gov>
> 发送时间: 2017年3月29日 12:46:30
> 收件人: lzf neu
> 抄送: tech-talk@aps.anl.gov
> 主题: Re: Question about PV name by using pcaspy
>> On Mar 29, 2017, at 3:37 AM, lzf neu <lzfneu@live.com> wrote:
>> Hi,
>> I want to fulfill a goal that when running camonitor command, PV name TEST:PING in the terminal window print "Disconnect!" or "OK!" alternatively.
>> However, I failed, "self.setParam('PING',a)"  seems only run once in the code and in terminal window only print one result.
>> I have posted the code in the following lines.
>> Could you give me some suggestions and any help will be appreciated.
> You’re missing a call to
>    self.updatePVs()
> -Kay
>> Zhefu
>> #!/usr/bin/env python
>> import os
>> import threading
>> import time
>> prefix = 'TEST:'
>> pvdb = {
>>     'PING' : {
>>          'type':'enum',
>>          'enums':['Disconnect!','OK!']
>>     def __init__(self):
>>         super(myDriver, self).__init__()
>>         tid=threading.Thread(target=self.determine)
>>         tid.setDaemon(True)
>>         tid.start()
>>     def determine(self):
>>         a=os.system("ping -c 1 -w 1 127.0.0.1")
>>         if (a==0):
>>           while True:
>>              a=not a
>>              time.sleep(5)
>>     driver = myDriver()
>>     while True:
>>         server.process(0.1)
Question about PV name by using pcaspy lzf neu
Re: Question about PV name by using pcaspy Kasemir, Kay
答复: Question about PV name by using pcaspy lzf neu
Prev: PCAS (using pcaspy) in docker ""server isnt attached to a network" Sparger, John E.
Next: Re: PCAS (using pcaspy) in docker ""server isnt attached to a network" Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: 答复: Question about PV name by using pcaspy lzf neu
Next: PCAS (using pcaspy) in docker ""server isnt attached to a network" Sparger, John E.
ANJ, 30 Mar 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
