1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Info on reading Sensus AMR UI-1203 protocol?
Date: Tue, 28 Mar 2017 09:26:13 -0500
I'm wondering if anyone has done anything with the Sensus AMR UI-1203 protocol and EPICS? This is used in residential water, gas, and electric meters so that the utility company can determine the customer's usage.
My work on the EPICS-based beer brewing system that some of you saw at the last ORNL EPICS meeting caught the attention of a brand new micro-distillery that is opening in the suburbs. So I'm working with them to automate their operation using EPICS. In this particular case, they need to measure out a specific volume of water to mix with grain. I'm considering using a Sensus water meter along with an actuated solenoid valve to do this.
Ryan
Prev: Driver for BK 9130B Dudley, David
Next: Re: Two VxWorks IOCs in one VME Crate Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Next: INP string length Siddons, David
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
