As it turns out, this error was caused by a broken NFS mount at the IOC.
The problem has been solved. There were some questions about OS version,
and NFS version..
RedHat Enterprise Linux 6.6 (32 bit)
NFS package version 3.2.29 (the ioc connects using nfs V3)
Thanks for the help!
Greg
On 3/24/17, 10:27 PM, "Paduan Donadio, Marcio" <[email protected]>
wrote:
>Hello, Greg.
>Here in SLAC, we faced the same problem but under Linux. We first ran the
>IOC with user1, generating autosave files with user1 as owner and next,
>we ran it with user2. The result was that on the second time, autosave
>tried to fchmod a file as user2, having user1 as the owner of the file,
>what is not allowed in Linux, and probably in your NFS server.
>If you change the owner of your autosave files, probably you will not see
>the messages anymore.
>Even having this solution, I see 2 improvement opportunities here:
>1 - autosave is changing file permissions by default and does this
>silently. I think this should be an option to be chosen by the IOC
>engineer.
>2 - autosave shows error -1 and this can be anything. There is no way to
>diagnose what is going on.
>I am working on a patch with some suggestions to address this, and I will
>make a GitHub pull request soon.
>I don't have experience with VxWorks, but maybe it can work for you,
>Greg. For now, if you want to build autosave without the need of changing
>file permissions, you can:
>- modify asApp/src/Makefile, adding:
>USR_CPPFLAGS += -DSET_FILE_PERMISSIONS=0
>- modify asApp/src/save_restore.c, changing:
>#ifndef _WIN32
> #ifndef SET_FILE_PERMISSIONS
> #define SET_FILE_PERMISSIONS 1
> #endif
>#endif
>Best regards,
>Márcio.
>________________________________________
>De: [email protected] <[email protected]> em nome
>de J. Lewis Muir <[email protected]>
>Enviado: quarta-feira, 22 de março de 2017 11:13
>Para: Lawson, Gregory S.
>Cc: [email protected]
>Assunto: Re: Vxworks nfs write error?
>On 03/17, Lawson, Gregory S. wrote:
>> Host is RHELWS kernel 2.6.32-642.
>What version of RHEL is that?
>What version of NFS is the server providing?
>Regards,
>Lewis
- Re: Vxworks nfs write error? Ron Sluiter
- Vxworks nfs write error? Lawson, Gregory S.
- Re: Vxworks nfs write error? J. Lewis Muir
- Re: Vxworks nfs write error? Paduan Donadio, Marcio
Re: CSS Alarm Handler Status Messages Kasemir, Kay
Questions about EDM and any help will be appreciated. lzf neu
<2017>
<2017>
