1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: CSS Alarm Handler Status Messages
To: Abdalla Ahmad <[email protected]>
Date: Mon, 27 Mar 2017 13:15:44 +0000
Hi:
The alarm handler simply reports the alarms provided by records.
On Mar 27, 2017, at 8:48 AM, Abdalla Ahmad <[email protected]> wrote:
Hello all
In the CSS Alarm Handler client we get alarms with these status messages:
1.       CALC_ALARM.
The calc record will set a CALC alarm when for example the formula in the CALC field is garbage.
2.       SCAN_ALARM.
EPICS IOC database processing logic sets this alarm if it cannot process a record.
3.       TIMEOUT_ALARM.
Device support code may set this alarm when it cannot communicate with a device
Can somebody explains what is the meaning of these messages and how to fix ?
Fix the underlying reason:
Enter a correct formula in the CALC field,
debug your IOC database,
check that the device is powered and the network cable is plugged in.
-Kay
CSS Alarm Handler Status Messages Abdalla Ahmad
Prev: CSS Alarm Handler Status Messages Abdalla Ahmad
Next: Re: Vxworks nfs write error? Lawson, Gregory S.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Next: Questions about EDM and any help will be appreciated. lzf neu
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
