Hi Marissa,
Regarding the limits issue, it sounds like a configuration issue.
Try changing the value of the below output record. The record only has two values 0, 1 for "Normally open switch", and "Normally closed switch". Most limit switches are normally closed
(value=1) for safety reasons.
DMC01:LIMITTYPE_CMD
DMC01:LIMITTYPE_STATUS
These records change the CN setting on the controller, check out CN in the 4080 command reference. Do an LD 0 to re-enable the limits, then test again.
Cheers,
Dr. Mark Clift
Senior Controls Engineer
Australian Synchrotron
800 Blackburn Road
Clayton 3168
Ph: +613 8540 4264
Fax: +613 8540 4200
Re: memory leak after unloading of ca.lib Carsten Winkler
EPICS meeting in May 15-18 at KURRI (3rd announce) 上窪田@KEKTokai
<2017>
RE: EPICS IOC asynMotorController error Mark Rivers
ORNL / US ITER Directorate Is Recruiting for: Instrumentation and Controls Lead Software Engineer / NB50620602 Cherry, Steve J.
<2017>
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
