Hi Carsten, Michael,
Sorry to revive this old thread. But I am facing similar problem to solve. This time not with Labview but with Python cffi.
From the discussion I understood that the workaround is not to unload libca/libCom.
On Linux, I have used the RTLD_NODELETE flag and that solve the problem.(https://linux.die.net/man/3/dlopen)
On 64bit Windows, I made a boring wrapper dll. https://github.com/CaChannel/caffi/tree/master/wrapper
The wrapper loads ca.dll with LoadLibrary call and calls the loaded symbols for the CA API. And at the end it does not call FreeLibrary, so that the loaded symbols live until the program ends. Do you guys see any problem with this approach?
Best
Xiaoqiang
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Carsten Winkler
Sent: Donnerstag, 23. Februar 2017 09:50
To: [email protected]
Subject: memory leak after unloading of ca.lib
Hi there,
when your project (e.g. LabVIEW) uses dynamic loading and unloading of channel access classes your main class will sometimes (at 64 bit nearly
always) crush with a segmentation fault. The reason seems to be missing
free() and delete functions in EPICS Base 3.14.12.6 (I'm sure this applies also to other EPICS Base versions).
I wrote a tiny test case to check it and it would be great to get any advise to solve the issue.
Best regards
Carsten
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
- Re: memory leak after unloading of ca.lib Carsten Winkler
- Re: memory leak after unloading of ca.lib Xiaoqiang Wang
- memory leak after unloading of ca.lib Carsten Winkler
websocket device support Geoffrey Savage
<2017>
RE: memory leak after unloading of ca.lib Hill, Jeff
<2017>
