Hello, Thanks for all the advice with figuring this out. There is definitely a limit issue as the .LLS is set
to one so the motor thinks it is at the low limit switch, but VAL
is within both limits set in the record: VAL = 46.665 LLM = -10 and
HLM = 200. The dial limits match LLM and HLM and DIR is set to
positive. Reading through the motor record documentation, I can't see
any other fields that could be triggering this limit switch.CNEN is set to enable with the record reflecting the correct motor type. Thank you again for the help, Marissa On Wed, Mar 22, 2017 at 7:18 AM, Ron Sluiter <[email protected]> wrote: Hello Marissa,
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
