We are having a problem when $(top) is redefined recursively for a subschematic. What happens is that links between records in the subschematic get $(top) expanded 3 times instead of only once.-------- [schematic2] uniq 1 [tools] [detail] [cell use] use subschematic 0 0 100 0 subschematic#1 xform 0 128 96 [comments] subschematic.sch: -------- [schematic2] uniq 2 [tools] [detail] w 258 74 -100 0 n#1 estringinval.si.FLNK 256 64 336 64 336 176 464 176 eaos.ao.SLNK [cell use] use estringinval 146 -32 100 0 si xform 0 128 48 p 62 -32 100 0 -1 PV:$(top) use eaos 607 81 100 0 ao xform 0 592 176 p 523 81 100 0 -1 PV:$(top) [comments] subschematic.sym: -------- [symbol2] bbox -288 -40 -32 152 uniq 27 [tools] [attributes] p -271 -19 100 0 -1 set0:top $(top)subschematic: [layers] <symbol> l 100 0 0 -232 72 SUBSCHEMATIC r 0 -288 -40 -32 152 [comments] The database that's generated by TDCT: (look at the FLNK field of the first record) -------- #= database generated by tdct V2.14.4 #= (mode: Capfast compatibility) record(stringin,"$(top)subschematic:si") { field(DESC,"string input record") field(SCAN,"Passive") field(PINI,"NO") field(PHAS,"0") field(EVNT,"0") field(DTYP,"Soft Channel") field(DISV,"1") field(SDIS,"0.000000000000000e+00") field(DISS,"NO_ALARM") field(PRIO,"LOW") field(FLNK,"$(top)subschematic:subschematic:subschematic:ao.VAL") field(VAL,"string") field(INP,"0.000000000000000e+00") field(SIOL,"0.000000000000000e+00") field(SIML,"0.000000000000000e+00") field(SIMS,"NO_ALARM") } record(ao,"$(top)subschematic:ao") { field(DESC,"analog output record") field(SCAN,"Passive") field(PINI,"NO") field(PHAS,"0") field(EVNT,"0") field(DTYP,"Soft Channel") field(DISV,"1") field(SDIS,"0.000000000000000e+00") field(DISS,"NO_ALARM") field(PRIO,"LOW") field(FLNK,"0.000000000000000e+00") field(OUT,"0.000000000000000e+00") field(OROC,"0.0000000e+00") field(DOL,"0.000000000000000e+00") field(OMSL,"supervisory") field(OIF,"Full") field(PREC,"0") field(LINR,"NO CONVERSION") field(EGUF,"0.0000000e+00") field(EGUL,"0.0000000e+00") field(EGU,"volts") field(DRVH,"0.0000000e+00") field(DRVL,"0.0000000e+00") field(HOPR,"0.0000000e+00") field(LOPR,"0.0000000e+00") field(HIHI,"0.0000000e+00") field(LOLO,"0.0000000e+00") field(HIGH,"0.0000000e+00") field(LOW,"0.0000000e+00") field(HHSV,"NO_ALARM") field(LLSV,"NO_ALARM") field(HSV,"NO_ALARM") field(LSV,"NO_ALARM") field(HYST,"0.000000000000000e+00") field(ADEL,"0.000000000000000e+00") field(MDEL,"0.000000000000000e+00") field(SIOL,"0.000000000000000e+00") field(SIML,"0.000000000000000e+00") field(SIMS,"NO_ALARM") field(IVOA,"Continue normally") field(IVOV,"0.000000000000000e+00") } Is there a newer version of TDCT which fixes this? Or might we have something configured wrong? Thanks, -- Mike Westfall Control Systems Software Engineer
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
