1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: AreaDetector / ADURL queries
To: "EPICS Tech-Talk ([email protected])" <[email protected]>
Date: Fri, 17 Mar 2017 14:13:50 +0000
I have been working with AreaDetector and the URL driver.
This is aimed at providing a training module that uses an IP camera.
I’ve been working with release R1-9-1 (I believe this is the newest of the 1.x releases), using medm and the EPICS AD Viewer plugin of ImageJ.
I’m working with an Ubuntu /x64 14.04.3 in a VM.
I have GraphicsMagick 1.3.18.
However, I think my questions remain pertinent to release R2-5.
Questions:
1. In start_epics, I suspect that:
        medm -x -macro "P=13SIM1:, R=cam1:" simDetector.adl & is meant to be:
        medm -x -macro "P=13URL1:, R=cam1:" URLDriver.adl &
2. In st.cmd, in the line:
        {URLDriverConfig("$(PORT)", 0, 0)
    Is the brace character intended, or is a typo?
    I can make it work if the brace is removed.
3.  In st.cmd, some lines refer to R=cam1:, whereas some lines refer to R=image1:, is this intended?
     e.g.
        dbLoadRecords("$(ADURL)/db/URLDriver.template","P=$(PREFIX),R=cam1:,PORT=$(PORT),ADDR=0,TIMEOUT=1")
     and
        dbLoadRecords("$(ADCORE)/db/NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),TYPE=Int8,FTVL=UCHAR,NELEMENTS=12582912")
     I can make it work if I change R=image1: to R=cam1:
4. In auto_settings.req some lines refer to R=cam1:, and some refer to R=image1:, is this intended?
    Again, I can make it work if I change R=image1: to R=cam1:
5. The issue I haven’t been able to resolve is this (see screen shot):
I believe the software is correctly collecting image data frames, and the ImageJ plugin shows green with correct connection.
But – I don’t see any picture...
What could I be missing here?
I note that the “Colour mode” is Mono, where the camera has colour.
I also tried this with images/sun.jpg, which is definitely a colour picture.
Many thanks for help received,
Peter.
Re: AreaDetector / ADURL queries Ralph Lange
Re: AreaDetector / ADURL queries Bruno Martins
Prev: Streamdevice & variable length data Konrad, Martin
Next: Re: Asyn 4-30 Problem on Arm processor Jörn Dreyer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: Streamdevice & variable length data Dirk Zimoch
Next: Re: AreaDetector / ADURL queries Ralph Lange
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
