Hi Mark,
I could not use StreamDevice because of hardware issues. It turned out that
these devices need special configurations of the serial interface which can not
be set using the standard asynSerialPort driver. In addition there are some
commands that need to combine the values from more than one PV into the output
stream.
Removing PINI in all records did not change the result.
I'm trying now which of the records is causing the problem.
As soon as I include one record with type asynFloat64 it crashes.
I will try tu run the code on x86_64 under vagrind and see what happens.
Jörn
- RE: Asyn 4-30 Problem on Arm processor Mark Rivers
- Asyn 4-30 Problem on Arm processor Jörn Dreyer
- Re: Asyn 4-30 Problem on Arm processor Jörn Dreyer
<2017>
<2017>
