Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: RE: NTNDArrays, Java
To: "'Madden, Timothy J.'" <tmadden@aps.anl.gov>, "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Fri, 10 Mar 2017 17:25:32 +0000
Tim,
I suggest that you create a branch of ADCore with your new Java viewer code and push it to github.com/areaDetector/ADCore.  That way others can look at the code, test it, and make suggestions.
Has anyone else written a Java PVAccess client that receives NTNDArrays?
From: tech-talk-bounces@aps.anl.gov [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of Madden, Timothy J.
Sent: Friday, March 10, 2017 10:16 AM
To: tech-talk@aps.anl.gov
Subject: NTNDArrays, Java
I am playing with NTNDArrays. I generate them from AD 2-5 with a sim detector and the pva plugin.
pvget can display the arrays that pop out of the driver.
Now I am writing a java program to monitor and eventually display in Image J.
The code is below.
I problem I have is that the dimensions and uniqie ID seem to be abscent from the data.
Also, calling NTNDArray.wrap fails, as the returned data seems to be not a real NT ND Array.
Furtner, the image data is byte[] type. I can get out the Union or values, or call toString to get the raw data.
I am not sure how  Java figures out if the union is bytes or ints or whatever.
I will have to be able to ask the NTNDArray what its datatype is, then convert to ints or whatever the datatype is. Not sure how this is done.
I have looked at the C++ code for the PVA ADDriver in AD2-5, but there are differences between cpp and java interfaces.
Also I have to call wrapUnsafe to even convert  the PVStructure into NTNDArray, which makes no sense. wrap fails.
Thanks
Tim Madden
Code below:
    public static void main(String[] args) {
        // TODO Auto-generated method stub
        System.out.println("Maddens test java get image");
        if (true)
        PvaClient pva=PvaClient.get();
        PvaClientChannel mychannel = pva.channel("13SIM1:Pva1:Image");
        PvaClientMonitor pvamon=mychannel.monitor();
        //pvamon.connect();
        pvamon.start();
        PvaClientMonitorData easydata = pvamon.getData();
        while(true)
        pvamon.waitEvent(0);
        //String sc = easydata.showChanged();
        PVStructure pvs = easydata.getPVStructure();
        NTNDArray myarray =NTNDArray.wrapUnsafe(pvs);
        //String imgstr = myarray.toString();
        PVUnion pvu = myarray.getValue();
        PVStructureArray dims = myarray.getDimension();
        //org.epics.pvdata.pv.Field a = pvu.getField();
        //PVInt uniqid = myarray.getUniqueId();
        //PVStructureArray psa =myarray.getAttribute();
        System.out.println("got data ");
        pvamon.releaseEvent();
        System.out.println("Maddens test java end");
NTNDArrays, Java Madden, Timothy J.
Prev: RE: NTNDArrays, Java Madden, Timothy J.
Next: RE: NTNDArrays, Java Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Next: Re: StreamDevice Checksum Pseudo-Converter Florian Feldbauer
ANJ, 15 Mar 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
