1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Questions about css boy opi be run as a standalone program
Date: Fri, 10 Mar 2017 12:11:38 +0000
hi,
I want to consult you a question that can css boy opi be run as a standalone program under Linux system. So, I can double click to run the css boy opi interface directly rather than start CSS first then start boy opi in run mode.
Any help will be appreciated and thanks in advance!
Prev: Re: EPICS make problem Andrew Johnson
Next: Re: CaQtDM installation error on scientific linux 7.2 Mezger Anton Christian (PSI)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: call of ca_sg_test hangs on in preemptive mode Wang Xiaoqiang
Next: NTNDArrays, Java Madden, Timothy J.
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
