On 03/08, Ralph Lange wrote:
> Have you verified the return code of the segfaulting command? I think make
> uses that to determine if the command failed. IIRC, we had cases in Base
> where a failing script would not return 0 because of an output redirection.
You mean "would return 0" I assume.
Lewis
- EPICS make problem Benjamin Franksen
- Re: EPICS make problem Torsten Bögershausen
- 3.15 build rules suppress crash message [was: EPICS make problem] Ben Franksen
- Re: 3.15 build rules suppress crash message [was: EPICS make problem] Ralph Lange
call of ca_sg_test hangs on in preemptive mode Wang Xiaoqiang
<2017>
Re: 3.15 build rules suppress crash message [was: EPICS make problem] Ben Franksen
<2017>
