1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: BURT error while execution
To: tech-talk <[email protected]>
Date: Mon, 6 Mar 2017 13:42:24 +0530 (IST)
I am installed BURT in a sl7.2 machine but while logging the files through  command line as well as burt gooey, the below error pops up
Error log while using burtrb through command line
[vishrut@localhost linux-x86_64]$ ./burtrb -f req1.req -o snap1.snap -l /tmp/burtlog.read.log
**** The executable "caRepeater" couldn't be located
**** because of errno = "No such file or directory".
**** You may need to modify your PATH environment variable.
**** Unable to start "CA Repeater" process.
burtlog.read.log reads as
&column ... not connected so no ca_array_get_callback()
&data ... not connected so no ca_array_get_callback()
HPE3631ATestGetP25Volts ... not connected so no ca_array_get_callback()
Error log while using backup through GUI
[vishrut@localhost linux-x86_64]$ ./burtgooey
>burtrb -f /opt/epics/extensions/bin/linux-x86_64/req1.req -o vishrut_1170303_152653_0.snap -l /tmp/vishrut_1170303_152653_0.read.log -v <
sh: burtrb: command not found
Kindly suggest a solution for this.
Thanks
Arnab
Prev: CaQtDM installation error on scientific linux 7.2 Arnab Dasgupta
Next: Question related to PV record Vandana Yadav
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: CaQtDM installation error on scientific linux 7.2 Matt Newville
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
