Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: memory leak after unloading of ca.lib
To: <tech-talk@aps.anl.gov>
Date: Mon, 27 Feb 2017 17:37:04 -0600
On 02/23/2017 12:17 PM, Hill, Jeff wrote:
> As I recall there were issues occurring when the CA client code
> spawning the ca repeater, and other standalone autonomous threads,
> within a lab view process. If the lab view block explicitly, and
> abruptly, unloaded the ca client DLL, this could ultimately cause the
> still running ca repeater thread to crash due to its continuing to
> execute code no-longer mapped into virtual memory. The legacy fix was
> to cause the reference count on the DLL to be artificially
> incremented so that the DLL would stay in memory. Perhaps something
> changed in EPICS base, with the management API for windows 64 bit
> DLLs, or alternatively with newer versions of lab view which has
> eliminated this protection.
The base/src/libCom/osi/os/WIN32/osdThread.c file contains a DllMain()
routine for Com.dll which is what Jeff is describing above, although I
don't know how it works or if we may have somehow disabled it in more
recent releases. Those with more Windows knowledge than I are welcome to
comment and suggest if this can be made to fix Carsten's problem. Jeff's
original commit message when he added this routine in 2005 was:
> make certain that com.dll remains resident for its daemon threads even if the
> user explicitly uloads it (from a labView DLL)
Could the solution just be to give ca.dll its own copy of this routine?
- Andrew
RE: memory leak after unloading of ca.lib Hill, Jeff
memory leak after unloading of ca.lib Carsten Winkler
Prev: Re: Thorlabs (PM100USB and PM16 series) Power Meters Hinko Kocevar
Next: PCASpy 0.6.3 Wang Xiaoqiang (PSI)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: RE: memory leak after unloading of ca.lib Hill, Jeff
Next: RE: memory leak after unloading of ca.lib Hill, Jeff
ANJ, 02 Mar 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
