1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: Why we want Lua on the IOC
To: "Peterson, Kevin M." <[email protected]>, "Hill, Jeff" <[email protected]>, Ben Franksen <[email protected]>
Cc: "Tech Talk \([email protected]\)" <[email protected]>
Date: Fri, 24 Feb 2017 20:53:15 +0000
It's not Jeff's code, but if anyone wants to play around with Lua in EPICS, there's a Lua module in the synApps github project that has implemented much of the same stuff.
https://github.com/epics-modules/script
It has a lua replacement for the calc record, a lua IOC shell (though it requires the current development version of base-3.16), library linkages into asyn for communication with devices, and device support to use lua with regular record types. It's also been the basis for a motor driver that allows lua to be used to write motor controllers.
https://github.com/epics-modules/motor/pull/40
Documentation is a bit spotty, though. But the examples should be enough to get someone started.
Keenan
From: [email protected] [[email protected]] on behalf of Kevin Peterson [[email protected]]
Sent: Friday, February 24, 2017 10:59 AM
To: Hill, Jeff; Ben Franksen
Cc: Tech Talk ([email protected])
Subject: Re: Why we want Lua on the IOC
Jeff,
The things you've implemented so far sound really interesting and
useful.  Is any of the code on github?
Kevin
On 2/23/17 4:19 PM, Hill, Jeff wrote:
> Hi Ben,
> For reference, I have presented some talks on this topic at the last few EPICS meetings.
> So far I have implemented the following.
> o A Lua-based CA server event filtering system where a small Lua snippet in the channel name postfix serves as the filter
> o A Lua-based IOC shell, callable from the legacy IOC shell, which can also invoke all of the registered IOC shell commands
> o A Lua-based scripting record, where Lua provides a comprehensive feature set, compared to CALC.
> Thanks for your interest,
> Jeff
RE: Why we want Lua on the IOC Hill, Jeff
Re: Why we want Lua on the IOC Kevin Peterson
Prev: Re: memory leak after unloading of ca.lib Michael Davidsaver
Next: RE: Why we want Lua on the IOC Hill, Jeff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: Why we want Lua on the IOC Kevin Peterson
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
