Hi James,
In my experience what works well is to create an input record for each valid response format. Use SCAN="I/O Intr" on these input records; streamDevice will automatically look for matches in parallel.
Separately, create an output record (SCAN="Passive") to send out the command.
It may be possible to create a regular _expression_ that matches all your valid formats. Creating multiple input records turned out to be simpler in my case.
-Chris Ford
SLAC
Hello,
I’m using streamDevice to handle serial data with a protocol file.
I can get two different valid responses to the same command. Below are the protocol strings that match the two different responses:
%(\$1:C)f;L1;%(\$1:L1)f;;%(\$1:F1)f
%(\$1:C)f;;%(\$1:F1)f
What’s the easiest/most sensible way of making it accept either response?
I got it working by making one of the strings a mismatch condition but this means the record‘s severity is raised.
Thanks for any advice,
James
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify
us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
- streamDevice protocol - accept two different valid responses James.OHea
Re: memory leak after unloading of ca.lib Carsten Winkler (HZB)
Re: memory leak after unloading of ca.lib Michael Davidsaver
<2017>
CSS 4.3.x is not showing main help (Help Contents) Mazanec Tomáš
<2017>
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
