1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: memory leak after unloading of ca.lib
To: Carsten Winkler <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 23 Feb 2017 18:17:55 +0000
Hi Carsten,
As I recall there were issues occurring when the CA client code spawning the ca repeater, and other standalone autonomous threads, within a lab view process. If the lab view block explicitly, and abruptly, unloaded the ca client DLL, this could ultimately cause the still running ca repeater thread to crash due to its continuing to execute code no-longer mapped into virtual memory. The legacy fix was to cause the reference count on the DLL to be artificially incremented so that the DLL would stay in memory. Perhaps something changed in EPICS base, with the management API for windows 64 bit DLLs, or alternatively with newer versions of lab view which has eliminated this protection.
Jeff
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Carsten Winkler
> Sent: Thursday, February 23, 2017 1:50 AM
> To: [email protected]
> Subject: memory leak after unloading of ca.lib
> Hi there,
> when your project (e.g. LabVIEW) uses dynamic loading and unloading of
> channel access classes your main class will sometimes (at 64 bit nearly
> always) crush with a segmentation fault. The reason seems to be missing
> free() and delete functions in EPICS Base 3.14.12.6 (I'm sure this
> applies also to other EPICS Base versions).
> I wrote a tiny test case to check it and it would be great to get any
> advise to solve the issue.
> Best regards
> Carsten
> ________________________________
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher
> Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr.
> Jutta Koch-Unterseher
> Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> http://www.helmholtz-berlin.de
Re: memory leak after unloading of ca.lib Andrew Johnson
memory leak after unloading of ca.lib Carsten Winkler
Prev: RE: RE: Re: IOC Connecting Problem Mark Rivers
Next: Re: memory leak after unloading of ca.lib Ben Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: memory leak after unloading of ca.lib Michael Davidsaver
Next: Re: memory leak after unloading of ca.lib Andrew Johnson
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
