Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: memory leak after unloading of ca.lib
From: Carsten Winkler <carsten.winkler@helmholtz-berlin.de>
To: <tech-talk@aps.anl.gov>
Date: Thu, 23 Feb 2017 09:50:01 +0100
Hi there,
when your project (e.g. LabVIEW) uses dynamic loading and unloading of
channel access classes your main class will sometimes (at 64 bit nearly
always) crush with a segmentation fault. The reason seems to be missing
free() and delete functions in EPICS Base 3.14.12.6 (I'm sure this
applies also to other EPICS Base versions).
I wrote a tiny test case to check it and it would be great to get any
advise to solve the issue.
Best regards
Carsten
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Attachment: libtest-64.tar.gz
Description: application/gzip
Attachment: libtest-32.tar.gz
Re: memory leak after unloading of ca.lib Michael Davidsaver
RE: memory leak after unloading of ca.lib Hill, Jeff
RE: memory leak after unloading of ca.lib Wang Xiaoqiang (PSI)
Prev: Re: Segmentation fault at dbConvert.c in Ubuntu 32/64 bit Carsten Winkler
Next: RE: RE: Re: IOC Connecting Problem Pilkyu Jung
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: New releases of areaDetector drivers Mark Rivers
Next: Re: memory leak after unloading of ca.lib Michael Davidsaver
ANJ, 23 Mar 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
