1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: How access to an array value from a process variable using ca_array_get()?
To: Raquel Pérez Lázaro <[email protected]>
Cc: [email protected]
Date: Thu, 16 Feb 2017 10:48:26 -0600
On 02/15, Raquel Pérez Lázaro wrote:
> Hello,
> I am trying to read and write to an array value from a process
> variable using ca_array_get() function, but it is no clear for me
> how I should use this function in order to access to each element of
> the array and print its value.
> I would appreciate an example.
> Thank you,
> R. Perez
See the documentation for ca_array_get in the CA Reference Manual [1].
It suggests looking a "caExample.c in the example application created
by makeBaseApp.pl."  You can also look at the source code for the caget
program in EPICS Base 3.14 [2] (and 3.15 [3]) which has a caget function
which uses ca_array_get_callback or ca_array_get and also iterates over
the elements of the array and prints their values.
Lewis
[1] http://www.aps.anl.gov/epics/base/R3-14/12-docs/CAref.html#ca_get
[2] http://bazaar.launchpad.net/~epics-core/epics-base/3.14/view/head:/src/catools/caget.c
[3] http://bazaar.launchpad.net/~epics-core/epics-base/3.15/view/head:/src/ca/client/tools/caget.c
Re: How access to an array value from a process variable using ca_array_get()? Raquel Pérez Lázaro
Prev: Notes on building EDM for Linux Mint 17 bob.anderson
Next: Re: EDM compiling problems Mike Westfall
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: How access to an array value from a process variable using ca_array_get()? Raquel Pérez Lázaro
Next: Re: How access to an array value from a process variable using ca_array_get()? Raquel Pérez Lázaro
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
