Hi Mark,
Changing WITH_XML2 to YES solved the problem.
I had to change WITH_HDF5 to YES too, to resolve the similar error (missing header file for hdf5).
The reason why I set almost everything to NO in CONFIG_SITE.local is that I wanted to start small, build a bare minimum without dependencies and then add them later. I am new to areaDetector, and I thought that would be the right approach to learning how to configure and deploy new areaDetector support.
However, there is something more which is puzzling me now.
In RELEASE.local I have a line for ADPointGrey drivers
#ADPOINTGREY=$(AREA_DETECTOR)/ADPointGrey
but make terminates with:
make -C /home/eli_sw/epics/support/areaDetector-2-5/ADPointGrey install
make[1]: *** /home/eli_sw/epics/support/areaDetector-2-5/ADPointGrey: No such file or directory. Stop.
/home/eli_sw/epics/R3.15/configure/RULES_DIRS:88: recipe for target '/home/eli_sw/epics/support/areaDetector-2-5/ADPointGrey.install' failed
make: *** [/home/eli_sw/epics/support/areaDetector-2-5/ADPointGrey.install] Error 2
To test, I tried to commenting out in Makefile
#ifdef ADPOINTGREY
#DIRS := $(DIRS) $(ADPOINTGREY)
#$(ADPOINTGREY)_DEPEND_DIRS += $(ADCORE)
#endif
and it solves the problem.
Many thanks,
Marcin
-----Original Message-----
Sent: 14 February 2017 19:12
To: Marcin Lukaszewski <[email protected]>; [email protected]
Subject: RE: Problem compiling areaDetector-2-5
Hi Marcin,
I understand the problem. Your CONFIG_SITE.local file defines WITH_XML2=NO. In that case NDPosPlugin.h does not get installed in ADCore/ADApp/pluginSrc. The pluginTests directory should not try to build the test for NDPluginPos if WITH_XML2 is not YES, but it does. That is a bug and I have created an issue for it on Github.
Your build of ADCore is otherwise complete, so you could ignore the error. Or you could define WITH_XML2=YES, since that library is easy to install on Linux if is not already installed.
Is there a reason that you have set WITH_XML2, WITH_TIFF, WITH_NETCDF, etc. in your CONFIG_SITE.local to NO?
From: [email protected] [[email protected]] on behalf of Marcin Lukaszewski [[email protected]]
Sent: Tuesday, February 14, 2017 10:00 AM
To: [email protected]
Subject: Problem compiling areaDetector-2-5
Hi all,
I am trying to compile areaDetector R2-5 on Ubuntu 16.04 LTS I git clone areaDetector, ADCore, ADSupport and ADExample and git checkout to following versions:
areaDetector R2-5
ADCore R2-5
ADSupport R1-0
ADExample R2-2
EPICS setup:
base 3.15.4
asyn-4-30
autosave-5-7-1
busy-1-6-1
calc-3-4-2-1
seq-2-23
sscan-2-10-1
Below pasties to my areaDetector/configure files:
- areaDetector folder structure http://pastebin.com/5KmLn7Cb
- RELEASE_PATHS.local http://pastebin.com/JbzKhrTE
- RELEASE_LIBS.local http://pastebin.com/Eus4L5Fi
- RELEASE_PRODS.local http://pastebin.com/gDSyG2JT
- CONFIG_SITE.LOCAL http://pastebin.com/C7iumVfN
- RELEASE.local http://pastebin.com/a0BsWNAs
After setup above I am trying to make but compilation terminates with the error:
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DH5_NO_DEPRECATED_SYMBOLS -DH5Dopen_vers=2 -DH5Gcreate_vers=2 -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/eli_sw/epics/R3.15/include/compiler/gcc -I/home/eli_sw/epics/R3.15/include/os/Linux -I/home/eli_sw/epics/R3.15/include -I/home/eli_sw/epics/support/asyn-4-30/include -I/home/eli_sw/epics/support/areaDetector-2-5/ADCore/include -I/usr/local64/include -I/usr/include/libxml2 -c ../PosPluginWrapper.cpp
In file included from ../PosPluginWrapper.cpp:8:0:
../PosPluginWrapper.h:11:25: fatal error: NDPosPlugin.h: No such file or directory compilation terminated.
/home/eli_sw/epics/R3.15/configure/RULES_BUILD:234: recipe for target 'PosPluginWrapper.o' failed
make[4]: *** [PosPluginWrapper.o] Error 1
make[4]: Leaving directory '/home/eli_sw/epics/support_5_8_at15/areaDetector-2-5/ADCore/ADApp/pluginTests/O.linux-x86_64'
/home/eli_sw/epics/R3.15/configure/RULES_ARCHS:61: recipe for target 'install.linux-x86_64' failed
make[3]: *** [install.linux-x86_64] Error 2
make[3]: Leaving directory '/home/eli_sw/epics/support_5_8_at15/areaDetector-2-5/ADCore/ADApp/pluginTests'
/home/eli_sw/epics/R3.15/configure/RULES_DIRS:88: recipe for target 'pluginTests.install' failed
make[2]: *** [pluginTests.install] Error 2
make[2]: Leaving directory '/home/eli_sw/epics/support_5_8_at15/areaDetector-2-5/ADCore/ADApp'
/home/eli_sw/epics/R3.15/configure/RULES_DIRS:88: recipe for target 'ADApp.install' failed
make[1]: *** [ADApp.install] Error 2
make[1]: Leaving directory '/home/eli_sw/epics/support_5_8_at15/areaDetector-2-5/ADCore'
/home/eli_sw/epics/R3.15/configure/RULES_DIRS:88: recipe for target '/home/eli_sw/epics/support/areaDetector-2-5/ADCore.install' failed
make: *** [/home/eli_sw/epics/support/areaDetector-2-5/ADCore.install] Error 2
Full output you can find here: http://pastebin.com/y06WGJwX
Quick check if I have files in correct places gives me:
→ find -name "NDPosPlugin.h"
./ADCore/ADApp/pluginSrc/NDPosPlugin.h
→ find -name "PosPluginWrapper.h"
./ADCore/ADApp/pluginTests/PosPluginWrapper.h
What I am doing wrong? Is there anything else I have to setup to compile areaDetector?
Marcin
- RE: Problem compiling areaDetector-2-5 Mark Rivers
- Problem compiling areaDetector-2-5 Marcin Lukaszewski
Re: Problem compiling areaDetector-2-5 Nilson Pereira
How access to an array value from a process variable using ca_array_get()? Raquel Pérez Lázaro
<2017>
<2017>
