1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: Logbook entry error
To: "Kasemir, Kay" <[email protected]>, "Shroff, Kunal" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 14 Feb 2017 14:30:23 +0000
Thanks a lot Kay and Kunal. In fact, my proper tab Spiral2 Properties returned null. I’ve modified the code. Everything is ok now.
Best regards,
Charles-Henry
____________________________________________________
Mon agenda est à jour sous Outlook, je vous encourage à organiser
les réunions sous Outlook, nous gagnerons en efficacité
De : Kasemir, Kay [mailto:[email protected]]
Envoyé : lundi 13 février 2017 14:55
À : Patard Charles-Henri; Shroff, Kunal
Objet : Re: Logbook entry error
Hi:
On Feb 13, 2017, at 3:12 AM, Patard Charles-Henri <[email protected]> wrote:
I’m using the 4.2 CS-Studio sources and I try to build the Spiral2 operation version. I execute my version in RCP e4 compatibility mode and use a application model (xmi file). I still face problems. When I try to create a Logbook entry with popup menu or action button.
The error java.lang.NullPointerException at org.csstudio.logbook.ui.LogEntryWidget.updateUI(LogEntryWidget.java:1088)
is in code that tries to call updateUI() on one of the tabFolders of the logbook dialog:
Those tabs include the one for file attachments, a property tree, and one can add custom tabs. Did you add some custom tabs to the logbook dialog? Are you using the OLog, or some site-specific logbook?
-Kay
The java stack :
!ENTRY org.eclipse.ui 4 0 2017-02-10 10:05:22.579
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
    at org.eclipse.swt.SWT.error(SWT.java:4491)
    at org.eclipse.swt.SWT.error(SWT.java:4406)
    at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:138)
    at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3794)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3433)
    at org.eclipse.jface.window.Window.runEventLoop(Window.java:827)
    at org.eclipse.jface.window.Window.open(Window.java:803)
    at org.csstudio.logbook.ui.OpenLogEntryBuilderDialog.execute(OpenLogEntryBuilderDialog.java:45)
    at org.csstudio.ui.util.AbstractAdaptedHandler.execute(AbstractAdaptedHandler.java:53)
    at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:295)
    at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    at java.lang.reflect.Method.invoke(Method.java:497)
    at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
    at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:252)
    at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:234)
    at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
    at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
    at org.eclipse.core.commands.Command.executeWithChecks(Command.java:493)
    at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:486)
    at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
    at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:799)
    at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:675)
    at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:659)
    at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:592)
    at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
    at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4481)
    at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1329)
    at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3819)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3430)
    at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
    at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
    at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
    at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
    at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:654)
    at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:598)
    at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
    at org.csstudio.spiral2_op.utility.product.Workbench.runWorkbench(Workbench.java:141)
    at org.csstudio.startup.application.Application.startApplication(Application.java:264)
    at org.csstudio.startup.application.Application.start(Application.java:118)
    at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
    at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
    at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
Caused by: java.lang.NullPointerException
    at org.csstudio.logbook.ui.LogEntryWidget.access$16(LogEntryWidget.java:1000)
    at org.csstudio.logbook.ui.LogEntryWidget$20$3.run(LogEntryWidget.java:884)
    at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
    at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
    ... 53 more
Thanks
Préservons notre environnement, n’imprimez ce mail que si nécessaire.
Preserve our environment, print this email only if necessary.
<Charles-Henry PATARD.vcf><Charles-Henry PATARD2.vcf>
BEGIN:VCARD
VERSION:2.1
X-MS-SIGNATURE:YES
N;LANGUAGE=fr:PATARD;Charles-Henry
FN:Charles-Henry PATARD
ORG:GANIL;SDA/GIM
TEL;WORK;VOICE:(02) 31 45 49 05
ADR;WORK;PREF:;;Boulevard Henri Becquerel;Caen;;14000;France
LABEL;WORK;PREF;ENCODING=QUOTED-PRINTABLE:Boulevard Henri Becquerel=0D=0A=
14000  Caen France
X-MS-OL-DEFAULT-POSTAL-ADDRESS:2
EMAIL;PREF;INTERNET:[email protected]
X-MS-CARDPICTURE;TYPE=JPEG;ENCODING=BASE64:
 /9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAYEBQYFBAYGBQYHBwYIChAKCgkJChQODwwQFxQY
 GBcUFhYaHSUfGhsjHBYWICwgIyYnKSopGR8tMC0oMCUoKSj/2wBDAQcHBwoIChMKChMoGhYa
 KCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCj/wAAR
 CACUACcDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA
 AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkK
 FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWG
 h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl
 5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREA
 AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYk
 NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOE
 hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk
 5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD6UdwpAPU0oIwSTxVeQ7nOPoKRj2B4FAEk
 k4/g59zREMgk9fWoFGSKsr8qc+maAIJfmlx6cUUkIy5aigBw4yfSkpT93680lABEMtUs52xk
 evFJAOabcHkLQAkZ2R570Uk3CqtFACt14pKO1A6/SgCxCPlzVc/NN+NWT8kf0FVoeWJoASY5
 fHpRTHbLE+9FAEnanRDkU3tU0I/ligBLhsIB61Gnyxk+tLcHLgegoKkqFXk8ZoAr0VMI0Xlz
 z6UUAKOTipozhRjknmkDRnovP0oclUJHFACGMbsvyT2FMkkIwFG2kiyWJPJApkhBc+lACINz
 fMaKaBk4FFAFmIfMPzpZz0H406JflJ/CmSMu88ZI456CgBIgQufeo8Kv3jk+gqVyfLwcDgDi
 oKAAuei4Ue1FMooA0TwmT2qoBuYe9WZjiM+9QR9SfQUAEx4A7HJqKny/fx6cUygBlFFFAFu4
 PIHpTYuF57mkkOWanHhPoP50AQk5JNJQetFADKKKKALQfcQCOtOcqRzjmmR9SfQUknUD0FAB
 sU9P0NMMfv8AmKaetAYjoSKAAo2OOfoaKN57gH8KKAJ0+434Ux/vt9aKKAIz1ooooAZRRRQB
 /9k=
X-MS-OL-DESIGN;CHARSET=utf-8:<card xmlns="http://schemas.microsoft.com/office/outlook/12/electronicbusinesscards"; ver="1.0" layout="left" bgcolor="ffffff"><img xmlns="" align="fit" area="16" use="cardpicture"/><fld xmlns="" prop="name" align="left" dir="ltr" style="b" color="000000" size="10"/><fld xmlns="" prop="org" align="left" dir="ltr" color="000000" size="8"/><fld xmlns="" prop="title" align="left" dir="ltr" color="000000" size="8"/><fld xmlns="" prop="dept" align="left" dir="ltr" color="000000" size="8"/><fld xmlns="" prop="blank" size="8"/><fld xmlns="" prop="telwork" align="left" dir="ltr" color="000000" size="8"><label align="right" color="626262">Bureau</label></fld><fld xmlns="" prop="email" align="left" dir="ltr" color="000000" size="8"/><fld xmlns="" prop="addrwork" align="left" dir="ltr" color="000000" size="8"/><fld xmlns="" prop="blank" size="8"/><fld xmlns="" prop="blank" size="8"/><fld xmlns="" prop="blank" size="8"/><fld xmlns="" prop="blank" size="8"/><fld xmlns="" prop="blank" size="8"/><fld xmlns="" prop="blank" size="8"/><fld xmlns="" prop="blank" size="8"/><fld xmlns="" prop="blank" size="8"/></card>
REV:20140210T091139Z
END:VCARD
Logbook entry error Patard Charles-Henri
Prev: Re: Sequencer remote pvPut CA delay (specified behavior?) Benjamin Franksen
Next: Problem compiling areaDetector-2-5 Marcin Lukaszewski
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Logbook entry error Patard Charles-Henri
Next: Re: Long string command to device Dirk Zimoch
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
