1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: Epic-modbus build error
To: Olanrewaju Ogunmola <[email protected]>
Date: Sun, 5 Feb 2017 08:07:17 +0000
I did not see any error in what you sent, only a warning. So I think it actually built OK.
Sent from my iPhone
> On Feb 4, 2017, at 9:58 PM, Olanrewaju Ogunmola <[email protected]> wrote:
> Hi All,
> I'm a new Epic user and have successfully installed epic-base and asyn. however, I encounter the below error when i run make from the top directory of epic-modbus. Any advise on it.
> Thank you
> Lanre Ogunmola
> Graduate Research Affiliate
> University of Nebraska, Omaha
> make -C ./configure install
> make[1]: Entering directory '/home/steal/modbus-master/configure'
> perl /home/steal/base-3.14.12.5/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
> mkdir O.Common
> make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
>     T_A=linux-x86_64 install
> make[2]: Entering directory '/home/steal/modbus-master/configure/O.linux-x86_64'
> perl /home/steal/base-3.14.12.5/bin/linux-x86_64/convertRelease.pl checkRelease
> make[2]: Leaving directory '/home/steal/modbus-master/configure/O.linux-x86_64'
> make[1]: Leaving directory '/home/steal/modbus-master/configure'
> make -C ./modbusApp install
> make[1]: Entering directory '/home/steal/modbus-master/modbusApp'
> make -C ./src install
> make[2]: Entering directory '/home/steal/modbus-master/modbusApp/src'
> perl /home/steal/base-3.14.12.5/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
> mkdir O.Common
> make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
> make[3]: Entering directory '/home/steal/modbus-master/modbusApp/src/O.linux-x86_64'
> echo "../O.Common/modbus.dbd : ../Makefile" >> modbus.dbd.d
> Expanding dbd
> /home/steal/base-3.14.12.5/bin/linux-x86_64/dbExpand   -I. -I.. -I../O.Common -I../../../dbd -I/home/steal/asyn-master/dbd -I/home/steal/base-3.14.12.5/dbd -o modbus.dbd ../modbusInclude.dbd
> Installing created dbd file ../../../dbd/modbus.dbd
> mkdir ../../../dbd
> Installing dbd file ../../../dbd/modbusSupport.dbd
> Installing generic include file ../../../include/drvModbusAsyn.h
> mkdir ../../../include
> /usr/bin/gcc -c  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall       -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include    -I/home/steal/asyn-master/include -I/home/steal/base-3.14.12.5/include/os/Linux -I/home/steal/base-3.14.12.5/include        ../drvModbusAsyn.c
> /usr/bin/gcc -c  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall       -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include    -I/home/steal/asyn-master/include -I/home/steal/base-3.14.12.5/include/os/Linux -I/home/steal/base-3.14.12.5/include        ../modbusInterpose.c
> /usr/bin/g++ -c  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall       -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include    -I/home/steal/asyn-master/include -I/home/steal/base-3.14.12.5/include/os/Linux -I/home/steal/base-3.14.12.5/include        ../testModbusSyncIO.cpp
> /usr/bin/ar -rc    libmodbus.a         drvModbusAsyn.o modbusInterpose.o testModbusSyncIO.o
> /usr/bin/ranlib libmodbus.a
> /usr/bin/g++ -o libmodbus.so -shared -fPIC -Wl,-hlibmodbus.so -L/home/steal/asyn-master/lib/linux-x86_64 -L/home/steal/base-3.14.12.5/lib/linux-x86_64 -Wl,-rpath,/home/steal/asyn-master/lib/linux-x86_64 -Wl,-rpath,/home/steal/base-3.14.12.5/lib/linux-x86_64        -m64                drvModbusAsyn.o modbusInterpose.o testModbusSyncIO.o   -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
> Installing shared library ../../../lib/linux-x86_64/libmodbus.so
> mkdir ../../../lib
> mkdir ../../../lib/linux-x86_64
> Installing library ../../../lib/linux-x86_64/libmodbus.a
> perl /home/steal/base-3.14.12.5/bin/linux-x86_64/registerRecordDeviceDriver.pl ../O.Common/modbus.dbd modbus_registerRecordDeviceDriver /home/steal/modbus-master > modbus.tmp
> mv modbus.tmp modbus_registerRecordDeviceDriver.cpp
> /usr/bin/g++ -c  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall       -m64      -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include    -I/home/steal/asyn-master/include -I/home/steal/base-3.14.12.5/include/os/Linux -I/home/steal/base-3.14.12.5/include        modbus_registerRecordDeviceDriver.cpp
> modbus_registerRecordDeviceDriver.cpp:478:12: warning: ‘done’ defined but not used [-Wunused-variable]
>  static int done = Registration();
> /usr/bin/g++ -c  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall       -m64      -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include    -I/home/steal/asyn-master/include -I/home/steal/base-3.14.12.5/include/os/Linux -I/home/steal/base-3.14.12.5/include        ../modbusMain.cpp
> /usr/bin/g++ -o modbusApp  -L/home/steal/modbus-master/lib/linux-x86_64 -L/home/steal/asyn-master/lib/linux-x86_64 -L/home/steal/base-3.14.12.5/lib/linux-x86_64 -Wl,-rpath,/home/steal/modbus-master/lib/linux-x86_64 -Wl,-rpath,/home/steal/asyn-master/lib/linux-x86_64 -Wl,-rpath,/home/steal/base-3.14.12.5/lib/linux-x86_64        -m64                modbus_registerRecordDeviceDriver.o modbusMain.o   -lmodbus -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom
> Installing created file ../../../bin/linux-x86_64/modbusApp
> mkdir ../../../bin
> mkdir ../../../bin/linux-x86_64
> make[3]: Leaving directory '/home/steal/modbus-master/modbusApp/src/O.linux-x86_64'
> make[2]: Leaving directory '/home/steal/modbus-master/modbusApp/src'
> make -C ./Db install
> make[2]: Entering directory '/home/steal/modbus-master/modbusApp/Db'
> mkdir O.Common
> make[3]: Entering directory '/home/steal/modbus-master/modbusApp/Db/O.linux-x86_64'
> Installing template file ../../../db/bi_word.template
> mkdir ../../../db
> Installing template file ../../../db/bo_word.template
> Installing template file ../../../db/bi_bit.template
> Installing template file ../../../db/bo_bit.template
> Installing template file ../../../db/longin.template
> Installing template file ../../../db/longout.template
> Installing template file ../../../db/longinInt32.template
> Installing template file ../../../db/longoutInt32.template
> Installing template file ../../../db/mbbiDirect.template
> Installing template file ../../../db/mbboDirect.template
> Installing template file ../../../db/ai.template
> Installing template file ../../../db/ai_average.template
> Installing template file ../../../db/ao.template
> Installing template file ../../../db/aiFloat64.template
> Installing template file ../../../db/aoFloat64.template
> Installing template file ../../../db/intarray_in.template
> Installing template file ../../../db/intarray_out.template
> Installing template file ../../../db/stringin.template
> Installing template file ../../../db/stringout.template
> Installing template file ../../../db/stringWaveformIn.template
> Installing template file ../../../db/stringWaveformOut.template
> Installing template file ../../../db/statistics.template
> Installing template file ../../../db/asynRecord.template
> Installing template file ../../../db/poll_delay.template
> Installing template file ../../../db/poll_trigger.template
> make[3]: Leaving directory '/home/steal/modbus-master/modbusApp/Db/O.linux-x86_64'
> make[2]: Leaving directory '/home/steal/modbus-master/modbusApp/Db'
> make[1]: Leaving directory '/home/steal/modbus-master/modbusApp'
> make -C ./iocBoot install
> make[1]: Entering directory '/home/steal/modbus-master/iocBoot'
> make -C ./iocTest install
> make[2]: Entering directory '/home/steal/modbus-master/iocBoot/iocTest'
> perl /home/steal/base-3.14.12.5/bin/linux-x86_64/convertRelease.pl -a linux-x86_64 -t /home/steal/modbus-master envPaths
> perl /home/steal/base-3.14.12.5/bin/linux-x86_64/convertRelease.pl -a linux-x86_64 -t /home/steal/modbus-master cdCommands
> make[2]: Leaving directory '/home/steal/modbus-master/iocBoot/iocTest'
> make[1]: Leaving directory '/home/steal/modbus-master/iocBoot'
Epic-modbus build error Olanrewaju Ogunmola
Prev: Epic-modbus build error Olanrewaju Ogunmola
Next: Re: edm, Fedora 25, and Wayland Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Next: EPICS Driver for FTDI D2XX on Linux Juniper Willard
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
