Hi All, I'm a new Epic user and have successfully installed epic-base and asyn. however, I encounter the below error when i run make from the top directory of epic-modbus. Any advise on it.make -C ./configure install make[1]: Entering directory '/home/steal/modbus-master/configure' perl /home/steal/base-3.14.12.5/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../.. mkdir O.Common make -C O.linux-x86_64 -f ../Makefile TOP=../.. \ T_A=linux-x86_64 install make[2]: Entering directory '/home/steal/modbus-master/configure/O.linux-x86_64' perl /home/steal/base-3.14.12.5/bin/linux-x86_64/convertRelease.pl checkRelease make[2]: Leaving directory '/home/steal/modbus-master/configure/O.linux-x86_64' make[1]: Leaving directory '/home/steal/modbus-master/configure' make -C ./modbusApp install make[1]: Entering directory '/home/steal/modbus-master/modbusApp' make -C ./src install make[2]: Entering directory '/home/steal/modbus-master/modbusApp/src' perl /home/steal/base-3.14.12.5/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../.. mkdir O.Common make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \ T_A=linux-x86_64 install make[3]: Entering directory '/home/steal/modbus-master/modbusApp/src/O.linux-x86_64' echo "../O.Common/modbus.dbd : ../Makefile" >> modbus.dbd.d Expanding dbd /home/steal/base-3.14.12.5/bin/linux-x86_64/dbExpand -I. -I.. -I../O.Common -I../../../dbd -I/home/steal/asyn-master/dbd -I/home/steal/base-3.14.12.5/dbd -o modbus.dbd ../modbusInclude.dbd Installing created dbd file ../../../dbd/modbus.dbd mkdir ../../../dbd Installing dbd file ../../../dbd/modbusSupport.dbd Installing generic include file ../../../include/drvModbusAsyn.h mkdir ../../../include /usr/bin/gcc -c -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/steal/asyn-master/include -I/home/steal/base-3.14.12.5/include/os/Linux -I/home/steal/base-3.14.12.5/include ../drvModbusAsyn.c /usr/bin/gcc -c -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/steal/asyn-master/include -I/home/steal/base-3.14.12.5/include/os/Linux -I/home/steal/base-3.14.12.5/include ../modbusInterpose.c /usr/bin/g++ -c -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/steal/asyn-master/include -I/home/steal/base-3.14.12.5/include/os/Linux -I/home/steal/base-3.14.12.5/include ../testModbusSyncIO.cpp /usr/bin/ar -rc libmodbus.a drvModbusAsyn.o modbusInterpose.o testModbusSyncIO.o /usr/bin/ranlib libmodbus.a /usr/bin/g++ -o libmodbus.so -shared -fPIC -Wl,-hlibmodbus.so -L/home/steal/asyn-master/lib/linux-x86_64 -L/home/steal/base-3.14.12.5/lib/linux-x86_64 -Wl,-rpath,/home/steal/asyn-master/lib/linux-x86_64 -Wl,-rpath,/home/steal/base-3.14.12.5/lib/linux-x86_64 -m64 drvModbusAsyn.o modbusInterpose.o testModbusSyncIO.o -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-x86_64/libmodbus.so mkdir ../../../lib mkdir ../../../lib/linux-x86_64 Installing library ../../../lib/linux-x86_64/libmodbus.a perl /home/steal/base-3.14.12.5/bin/linux-x86_64/registerRecordDeviceDriver.pl ../O.Common/modbus.dbd modbus_registerRecordDeviceDriver /home/steal/modbus-master > modbus.tmp mv modbus.tmp modbus_registerRecordDeviceDriver.cpp /usr/bin/g++ -c -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -m64 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/steal/asyn-master/include -I/home/steal/base-3.14.12.5/include/os/Linux -I/home/steal/base-3.14.12.5/include modbus_registerRecordDeviceDriver.cpp modbus_registerRecordDeviceDriver.cpp:478:12: warning: ‘done’ defined but not used [-Wunused-variable] static int done = Registration(); ^ /usr/bin/g++ -c -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -m64 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/steal/asyn-master/include -I/home/steal/base-3.14.12.5/include/os/Linux -I/home/steal/base-3.14.12.5/include ../modbusMain.cpp /usr/bin/g++ -o modbusApp -L/home/steal/modbus-master/lib/linux-x86_64 -L/home/steal/asyn-master/lib/linux-x86_64 -L/home/steal/base-3.14.12.5/lib/linux-x86_64 -Wl,-rpath,/home/steal/modbus-master/lib/linux-x86_64 -Wl,-rpath,/home/steal/asyn-master/lib/linux-x86_64 -Wl,-rpath,/home/steal/base-3.14.12.5/lib/linux-x86_64 -m64 modbus_registerRecordDeviceDriver.o modbusMain.o -lmodbus -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom Installing created file ../../../bin/linux-x86_64/modbusApp mkdir ../../../bin mkdir ../../../bin/linux-x86_64 make[3]: Leaving directory '/home/steal/modbus-master/modbusApp/src/O.linux-x86_64' make[2]: Leaving directory '/home/steal/modbus-master/modbusApp/src' make -C ./Db install make[2]: Entering directory '/home/steal/modbus-master/modbusApp/Db' perl /home/steal/base-3.14.12.5/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../.. mkdir O.Common make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \ T_A=linux-x86_64 install make[3]: Entering directory '/home/steal/modbus-master/modbusApp/Db/O.linux-x86_64' Installing template file ../../../db/bi_word.template mkdir ../../../db Installing template file ../../../db/bo_word.template Installing template file ../../../db/bi_bit.template Installing template file ../../../db/bo_bit.template Installing template file ../../../db/longin.template Installing template file ../../../db/longout.template Installing template file ../../../db/longinInt32.template Installing template file ../../../db/longoutInt32.template Installing template file ../../../db/mbbiDirect.template Installing template file ../../../db/mbboDirect.template Installing template file ../../../db/ai.template Installing template file ../../../db/ai_average.template Installing template file ../../../db/ao.template Installing template file ../../../db/aiFloat64.template Installing template file ../../../db/aoFloat64.template Installing template file ../../../db/intarray_in.template Installing template file ../../../db/intarray_out.template Installing template file ../../../db/stringin.template Installing template file ../../../db/stringout.template Installing template file ../../../db/stringWaveformIn.template Installing template file ../../../db/stringWaveformOut.template Installing template file ../../../db/statistics.template Installing template file ../../../db/asynRecord.template Installing template file ../../../db/poll_delay.template Installing template file ../../../db/poll_trigger.template make[3]: Leaving directory '/home/steal/modbus-master/modbusApp/Db/O.linux-x86_64' make[2]: Leaving directory '/home/steal/modbus-master/modbusApp/Db' make[1]: Leaving directory '/home/steal/modbus-master/modbusApp' make -C ./iocBoot install make[1]: Entering directory '/home/steal/modbus-master/iocBoot' make -C ./iocTest install make[2]: Entering directory '/home/steal/modbus-master/iocBoot/iocTest' perl /home/steal/base-3.14.12.5/bin/linux-x86_64/convertRelease.pl -a linux-x86_64 -t /home/steal/modbus-master envPaths perl /home/steal/base-3.14.12.5/bin/linux-x86_64/convertRelease.pl -a linux-x86_64 -t /home/steal/modbus-master cdCommands make[2]: Leaving directory '/home/steal/modbus-master/iocBoot/iocTest' make[1]: Leaving directory '/home/steal/modbus-master/iocBoot'
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
