Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: Command omsMAXnetConfig not found
To: David Vine <dvine@lbl.gov>
Cc: tech-talk@aps.anl.gov
Date: Fri, 3 Feb 2017 11:41:40 -0600
David,
You may run into problems caused by noise on the limit lines of the
motors controlled by the MAXnet.  I incorrectly assumed it had the same
internal filters as the MAXv.  Here is the info I received from OMS on
the subject:
  "The MAXv has a DS14C89 line driver which has internal filters.  The
MAXnet does not utilize the DS14C89 driver."
I'm still waiting for a fix from ACS to add filters to the limit lines
of their SPI-MAXnet-8000.  It is mostly unusable in its default state.
Kevin
Re: Command omsMAXnetConfig not found David Vine
Re: Command omsMAXnetConfig not found Kevin Peterson
Prev: Re: Command omsMAXnetConfig not found David Vine
Next: Re: Command omsMAXnetConfig not found David Vine
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
ANJ, 14 Feb 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
