1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Command omsMAXnetConfig not found
To: [email protected]
Date: Fri, 3 Feb 2017 09:04:41 -0800
Hi all,
I'm trying to build an IOC to talk to a MAXnet controller using xxx-5-8 and motor-6-9 (synApps-5-8, base-3.15.5). Nothing in motor-6-9/motorApp/Makefile is deselected and synApps builds without error.
The st.cmd and boot output are below but the error is:
omsMAXnetConfig("MAXNET1" , 10, "MAXNET", 10, 1000, "")
st.cmd line 67: Command omsMAXnetConfig not found.
How do I tell the IOC where to find the maxnet support?
David
# MAXnet Serial
drvAsynSerialPortConfigure("MAXNET","/dev/ttyUSB0",0,0,0)
asynSetOption("MAXNET",0,"baud","115200")
asynSetOption("MAXNET",0,"bits","8")
asynSetOption("MAXNET",0,"parity","none")
asynSetOption("MAXNET",0,"crtscts","Y")
dbLoadRecords("$(ASYN)/db/asynRecord.db","P=oms:,R=maxnet,PORT=MAXNET,ADDR=0,OMAX=0,IMAX=0")
### Uncomment one of the following two lines:
#asynOctetSetInputEos("MAXNET",0,"\n\r")
asynOctetSetInputEos("MAXNET",0,"\n")
asynOctetSetOutputEos("MAXNET",0,"\n")
# omsMAXnetConfig(portName,              /* MAXnet Motor Asyn Port name */
#                 numAxes,               /* Number of axes this controller supports */
#                  serialPortName,       /* MAXnet Serial Asyn Port name */
#                  movingPollPeriod,     /* Time to poll (msec) when an axis is in motion */
#                  idlePollPeriod,       /* Time to poll (msec) when an axis is idle. 0 for no polling */
#                  initString)           /* Init String sent to card */
[david@dusk iocLinux]$ ../../bin/linux-x86_64/stxm st.cmd
# Linux startup script
# For devIocStats
epicsEnvSet("ENGINEER","engineer")
epicsEnvSet("LOCATION","location")
< envPaths
epicsEnvSet("IOC","iocLinux")
epicsEnvSet("TOP","/opt/epics/synApps_5_8/ioc/stxm")
epicsEnvSet("SUPPORT","/opt/epics/synApps_5_8/support")
epicsEnvSet("EPICS_BASE","/opt/epics/base")
epicsEnvSet("ALIVE","/opt/epics/synApps_5_8/support/alive-1-0")
epicsEnvSet("ALLEN_BRADLEY","/opt/epics/synApps_5_8/support/allenBradley-2-3")
epicsEnvSet("AREA_DETECTOR","/opt/epics/synApps_5_8/support/areaDetector")
epicsEnvSet("ADCORE","/opt/epics/synApps_5_8/support/areaDetector/ADCore")
epicsEnvSet("ADBINARIES","/opt/epics/synApps_5_8/support/areaDetector/ADBinaries")
epicsEnvSet("ASYN","/opt/epics/synApps_5_8/support/asyn-4-30")
epicsEnvSet("AUTOSAVE","/opt/epics/synApps_5_8/support/autosave-5-7-1")
epicsEnvSet("BUSY","/opt/epics/synApps_5_8/support/busy-1-6-1")
epicsEnvSet("CALC","/opt/epics/synApps_5_8/support/calc-3-4-2-1")
epicsEnvSet("CAMAC","/opt/epics/synApps_5_8/support/camac-2-7")
epicsEnvSet("CAPUTRECORDER","/opt/epics/synApps_5_8/support/caputRecorder-1-5-1")
epicsEnvSet("DAC128V","/opt/epics/synApps_5_8/support/dac128V-2-8")
epicsEnvSet("DELAYGEN","/opt/epics/synApps_5_8/support/delaygen-1-1-1")
epicsEnvSet("DEVIOCSTATS","/opt/epics/synApps_5_8/support/devIocStats-3-1-13")
epicsEnvSet("IP","/opt/epics/synApps_5_8/support/ip-2-17")
epicsEnvSet("IP330","/opt/epics/synApps_5_8/support/ip330-2-8")
epicsEnvSet("IPAC","/opt/epics/synApps_5_8/support/ipac-2-14")
epicsEnvSet("IPUNIDIG","/opt/epics/synApps_5_8/support/ipUnidig-2-10")
epicsEnvSet("LOVE","/opt/epics/synApps_5_8/support/love-3-2-5")
epicsEnvSet("MCA","/opt/epics/synApps_5_8/support/mca-7-6")
epicsEnvSet("MEASCOMP","/opt/epics/synApps_5_8/support/measComp-1-1")
epicsEnvSet("MODBUS","/opt/epics/synApps_5_8/support/modbus-2-7")
epicsEnvSet("MOTOR","/opt/epics/synApps_5_8/support/motor-6-9")
epicsEnvSet("OPTICS","/opt/epics/synApps_5_8/support/optics-2-9-3")
epicsEnvSet("SNCSEQ","/opt/epics/synApps_5_8/support/seq-2-2-3")
epicsEnvSet("SOFTGLUE","/opt/epics/synApps_5_8/support/softGlue-2-4-3")
epicsEnvSet("SSCAN","/opt/epics/synApps_5_8/support/sscan-2-10")
epicsEnvSet("STD","/opt/epics/synApps_5_8/support/std-3-4")
epicsEnvSet("STREAM","/opt/epics/synApps_5_8/support/stream-2-6a")
epicsEnvSet("VAC","/opt/epics/synApps_5_8/support/vac-1-5-1")
epicsEnvSet("VME","/opt/epics/synApps_5_8/support/vme-2-8-2")
epicsEnvSet("XXX","/opt/epics/synApps_5_8/support/xxx-5-8")
# save_restore.cmd needs the full path to the startup directory, which
# envPaths currently does not provide
epicsEnvSet(STARTUP,/opt/epics/synApps_5_8/ioc/stxm/iocBoot/iocLinux)
# Increase size of buffer for error logging from default 1256
errlogInit(20000)
# Specify largest array CA will transport
# Note for N doubles, need N*8 bytes+some overhead
epicsEnvSet EPICS_CA_MAX_ARRAY_BYTES 64010
epicsEnvSet ("STREAM_PROTOCOL_PATH", ".:../protocols")
# Tell EPICS all about the record types, device-support modules, drivers,
# etc. in the software we just loaded (stxm.munch)
dbLoadDatabase("../../dbd/iocstxmLinux.dbd")
iocstxmLinux_registerRecordDeviceDriver(pdbbase)
### save_restore setup
< save_restore.cmd
# BEGIN save_restore.cmd ------------------------------------------------------
# status PVs
#save_restoreSet_UseStatusPVs(1)
save_restoreSet_status_prefix("stxm:")
dbLoadRecords("/opt/epics/synApps_5_8/support/autosave-5-7-1/asApp/Db/save_restoreStatus.db", "P=stxm:, DEAD_SECONDS=5")
# Ok to save/restore save sets with missing values (no CA connection to PV)?
save_restoreSet_IncompleteSetsOk(1)
# Save dated backup files?
save_restoreSet_DatedBackupFiles(1)
# Number of sequenced backup files to write
save_restoreSet_NumSeqFiles(3)
# Time interval between sequenced backups
save_restoreSet_SeqPeriodInSeconds(300)
# Ok to retry connecting to PVs whose initial connection attempt failed?
save_restoreSet_CAReconnect(1)
# Time interval in seconds between forced save-file writes.  (-1 means forever).
# This is intended to get save files written even if the normal trigger mechanism is broken.
save_restoreSet_CallbackTimeout(-1)
# specify where save files should be
set_savefile_path("/opt/epics/synApps_5_8/ioc/stxm/iocBoot/iocLinux", "autosave")
# specify what save files should be restored.  Note these files must be
# in the directory specified in set_savefile_path(), or, if that function
# has not been called, from the directory current when iocInit is invoked
set_pass0_restoreFile("auto_positions.sav", "P=stxm:")
# Save positions every five seconds
doAfterIocInit("create_monitor_set('auto_positions.req',5,'P=stxm:')")
set_pass0_restoreFile("auto_settings.sav", "P=stxm:")
set_pass1_restoreFile("auto_settings.sav", "P=stxm:")
# save settings every thirty seconds
doAfterIocInit("create_monitor_set('auto_settings.req',30,'P=stxm:')")
# Note that you can reload these sets after creating them: e.g.,
# reload_monitor_set("auto_settings.req",30,"P=stxm:")
# Note that you can restore a .sav file without also autosaving to it.
#set_pass0_restoreFile("myInitData.sav")
#set_pass1_restoreFile("myInitData.sav")
# Also, you can restore a .sav file that contains macros. (autosave R5-4-2)
#set_pass0_restoreFile("myGenericData.sav", "P=stxm:")
#set_pass1_restoreFile("myGenericData.sav", "P=stxm:")
# specify directories in which to to search for included request files
set_requestfile_path("/opt/epics/synApps_5_8/ioc/stxm/iocBoot/iocLinux", "")
set_requestfile_path("/opt/epics/synApps_5_8/ioc/stxm/iocBoot/iocLinux", "autosave")
set_requestfile_path("/opt/epics/synApps_5_8/support/areaDetector", "ADApp/Db")
set_requestfile_path("/opt/epics/synApps_5_8/support/areaDetector/ADCore", "ADApp/Db")
set_requestfile_path("/opt/epics/synApps_5_8/support/autosave-5-7-1", "asApp/Db")
set_requestfile_path("/opt/epics/synApps_5_8/support/busy-1-6-1", "busyApp/Db")
set_requestfile_path("/opt/epics/synApps_5_8/support/calc-3-4-2-1", "calcApp/Db")
set_requestfile_path("/opt/epics/synApps_5_8/support/camac-2-7", "camacApp/Db")
set_requestfile_path("/opt/epics/synApps_5_8/support/caputRecorder-1-5-1", "caputRecorderApp/Db")
set_requestfile_path("/opt/epics/synApps_5_8/support/dac128V-2-8", "dac128VApp/Db")
set_requestfile_path("/opt/epics/synApps_5_8/support/delaygen-1-1-1", "delaygenApp/Db")
macLib: macro DXP is undefined (expanding string set_requestfile_path("$(DXP)", "dxpApp/Db"))
set_requestfile_path("/opt/epics/synApps_5_8/support/ip-2-17", "ipApp/Db")
set_requestfile_path("/opt/epics/synApps_5_8/support/ip330-2-8", "ip330App/Db")
set_requestfile_path("/opt/epics/synApps_5_8/support/ipUnidig-2-10", "ipUnidigApp/Db")
set_requestfile_path("/opt/epics/synApps_5_8/support/love-3-2-5", "loveApp/Db")
set_requestfile_path("/opt/epics/synApps_5_8/support/mca-7-6", "mcaApp/Db")
set_requestfile_path("/opt/epics/synApps_5_8/support/measComp-1-1", "measCompApp/Db")
set_requestfile_path("/opt/epics/synApps_5_8/support/modbus-2-7", "modbusApp/Db")
set_requestfile_path("/opt/epics/synApps_5_8/support/motor-6-9", "motorApp/Db")
set_requestfile_path("/opt/epics/synApps_5_8/support/optics-2-9-3", "opticsApp/Db")
macLib: macro QUADEM is undefined (expanding string set_requestfile_path("$(QUADEM)", "quadEMApp/Db"))
set_requestfile_path("/opt/epics/synApps_5_8/support/sscan-2-10", "sscanApp/Db")
set_requestfile_path("/opt/epics/synApps_5_8/support/softGlue-2-4-3", "softGlueApp/Db")
set_requestfile_path("/opt/epics/synApps_5_8/support/std-3-4", "stdApp/Db")
set_requestfile_path("/opt/epics/synApps_5_8/support/vac-1-5-1", "vacApp/Db")
set_requestfile_path("/opt/epics/synApps_5_8/support/vme-2-8-2", "vmeApp/Db")
set_requestfile_path("/opt/epics/synApps_5_8/ioc/stxm", "stxmApp/Db")
# Debug-output level
save_restoreSet_Debug(0)
# Tell autosave to automatically build built_settings.req and
# built_positions.req from databases and macros supplied to dbLoadRecords()
# (and dbLoadTemplate(), which calls dbLoadRecords()).
epicsEnvSet("BUILT_SETTINGS", "built_settings.req")
epicsEnvSet("BUILT_POSITIONS", "built_positions.req")
autosaveBuild("built_settings.req", "_settings.req", 1)
pretending to register a dbLoadRecords hook
autosaveBuild("built_positions.req", "_positions.req", 1)
# END save_restore.cmd --------------------------------------------------------
# Access Security
dbLoadRecords("/opt/epics/synApps_5_8/ioc/stxm/stxmApp/Db/Security_Control.db","P=stxm:")
asSetFilename("/opt/epics/synApps_5_8/ioc/stxm/iocBoot/accessSecurity.acf")
asSetSubstitutions("P=stxm:")
# soft scaler for testing
< softScaler.cmd
# soft scaler
dbLoadRecords("/opt/epics/synApps_5_8/support/asyn-4-30/db/asynRecord.db","P=stxm:,R=asynScaler,PORT=scaler1Port,ADDR=0,OMAX=0,IMAX=0")
# drvScalerSoftConfigure(char *portName, int maxChans, char *pvTemplate)
drvScalerSoftConfigure("scaler1Port", 8, "stxm:scaler1:s%d")
dbLoadRecords("/opt/epics/synApps_5_8/support/std-3-4/stdApp/Db/scaler.db","P=stxm:,S=scaler1,OUT=@asyn(scaler1Port 0 0),DTYP=Asyn Scaler,FREQ=10000000")
dbLoadRecords("/opt/epics/synApps_5_8/support/std-3-4/stdApp/Db/scalerSoftCtrl.db","P=stxm:,Q=scaler1:,SCALER=stxm:scaler1")
# user-assignable ramp/tweak
dbLoadRecords("/opt/epics/synApps_5_8/support/std-3-4/stdApp/Db/ramp_tweak.db","P=stxm:,Q=rt1")
### Motors
dbLoadTemplate("motor.substitutions.MAXnet")
dbLoadTemplate: error opening sub file motor.substitutions.MAXnet
#dbLoadTemplate("MAXnetAux.substitutions")
# MAXnet IP
#drvAsynIPPortConfigure("MAXNET","maxnet-ip-address:23",0,0,0)
# MAXnet Serial
dbLoadRecords("/opt/epics/synApps_5_8/support/asyn-4-30/db/asynRecord.db","P=oms:,R=maxnet,PORT=MAXNET,ADDR=0,OMAX=0,IMAX=0")
### Scan-support software
# crate-resident scan.  This executes 1D, 2D, 3D, and 4D scans, and caches
# 1D data, but it doesn't store anything to disk.  (See 'saveData' below for that.)
dbLoadRecords("/opt/epics/synApps_5_8/support/sscan-2-10/sscanApp/Db/standardScans.db","P=stxm:,MAXPTS1=1000,MAXPTS2=1000,MAXPTS3=1000,MAXPTS4=1000,MAXPTSH=1000")
dbLoadRecords("/opt/epics/synApps_5_8/support/sscan-2-10/sscanApp/Db/saveData.db","P=stxm:")
# Run this after iocInit:
doAfterIocInit("saveData_Init(saveData.req, 'P=stxm:')")
dbLoadRecords("/opt/epics/synApps_5_8/support/sscan-2-10/sscanApp/Db/scanProgress.db","P=stxm:scanProgress:")
doAfterIocInit("seq &scanProgress, 'S=stxm:, P=stxm:scanProgress:'")
# configMenu example.
dbLoadRecords("/opt/epics/synApps_5_8/support/autosave-5-7-1/asApp/Db/configMenu.db","P=stxm:,CONFIG=scan1")
# Note that the request file MUST be named $(CONFIG)Menu.req
# If the macro CONFIGMENU is defined with any value, backup (".savB") and
# sequence files (".savN") will not be written.  We don't want these for configMenu.
doAfterIocInit("create_manual_set('scan1Menu.req','P=stxm:,CONFIG=scan1,CONFIGMENU=1')")
# You could make scan configurations read-only:
#dbLoadRecords("$(AUTOSAVE)/asApp/Db/configMenu.db","P=stxm:,CONFIG=scan1,ENABLE_SAVE=0")
# read-only configMenu example.  (Read-only, because we're not calling create_manual_set().)
#dbLoadRecords("$(AUTOSAVE)/asApp/Db/configMenu.db","P=stxm:,CONFIG=scan2")
# A set of scan parameters for each positioner.  This is a convenience
# for the user.  It can contain an entry for each scannable thing in the
# crate.
dbLoadTemplate("scanParms.substitutions")
### Stuff for user programming ###
< calc.cmd
dbLoadRecords("/opt/epics/synApps_5_8/support/calc-3-4-2-1/calcApp/Db/userCalcs10.db","P=stxm:")
appendToFile("built_settings.req", '$(P)userCalcEnable')
dbLoadRecords("/opt/epics/synApps_5_8/support/calc-3-4-2-1/calcApp/Db/userCalcOuts10.db","P=stxm:")
appendToFile("built_settings.req", '$(P)userCalcOutEnable')
dbLoadRecords("/opt/epics/synApps_5_8/support/calc-3-4-2-1/calcApp/Db/userCalcOuts10more.db","P=stxm:,N1=11,N2=12,N3=13,N4=14,N5=15,N6=16,N7=17,N8=18,N9=19,N10=20")
dbLoadRecords("/opt/epics/synApps_5_8/support/calc-3-4-2-1/calcApp/Db/userStringCalcs10.db","P=stxm:")
appendToFile("built_settings.req", '$(P)userStringCalcEnable')
dbLoadRecords("/opt/epics/synApps_5_8/support/calc-3-4-2-1/calcApp/Db/userArrayCalcs10.db","P=stxm:,N=8000")
appendToFile("built_settings.req", '$(P)userArrayCalcEnable')
dbLoadRecords("/opt/epics/synApps_5_8/support/calc-3-4-2-1/calcApp/Db/userTransforms10.db","P=stxm:")
appendToFile("built_settings.req", '$(P)userTranEnable')
dbLoadRecords("/opt/epics/synApps_5_8/support/calc-3-4-2-1/calcApp/Db/userAve10.db","P=stxm:")
# string sequence (sseq) records
dbLoadRecords("/opt/epics/synApps_5_8/support/calc-3-4-2-1/calcApp/Db/userStringSeqs10.db","P=stxm:")
appendToFile("built_settings.req", '$(P)userStringSeqEnable')
# editSseq - edit any sseq or seq record
dbLoadRecords("/opt/epics/synApps_5_8/support/calc-3-4-2-1/calcApp/Db/editSseq.db", "P=stxm:,Q=ES:")
doAfterIocInit("seq &editSseq, 'P=stxm:,Q=ES:'")
# interpolation
dbLoadRecords("/opt/epics/synApps_5_8/support/calc-3-4-2-1/calcApp/Db/interp.db", "P=stxm:,N=2000")
dbLoadRecords("/opt/epics/synApps_5_8/support/calc-3-4-2-1/calcApp/Db/interpNew.db", "P=stxm:,Q=1,N=2000")
# pvHistory (in-crate archive of up to three PV's)
dbLoadRecords("/opt/epics/synApps_5_8/support/std-3-4/stdApp/Db/pvHistory.db","P=stxm:,N=1,MAXSAMPLES=1440")
# busy record
dbLoadRecords("/opt/epics/synApps_5_8/support/busy-1-6-1/busyApp/Db/busyRecord.db", "P=stxm:,R=mybusy")
dbLoadRecords("/opt/epics/synApps_5_8/support/busy-1-6-1/busyApp/Db/busyRecord.db", "P=stxm:,R=mybusy2")
# Soft function generator
#dbLoadRecords("$(CALC)/calcApp/Db/FuncGen.db","P=stxm:,Q=fgen,OUT=stxm:m7.VAL")
# Slow feedback
dbLoadTemplate "pid_slow.substitutions"
dbLoadTemplate "async_pid_slow.substitutions"
#dbLoadTemplate "fb_epid.substitutions"
# Miscellaneous PV's, such as burtResult
dbLoadRecords("/opt/epics/synApps_5_8/support/std-3-4/stdApp/Db/misc.db","P=stxm:")
# devIocStats
dbLoadRecords("/opt/epics/synApps_5_8/support/devIocStats-3-1-13/db/iocAdminSoft.db","IOC=stxm")
### Load database record for alive heartbeating support.
# RHOST specifies the IP address that receives the heartbeats.
#dbLoadRecords("$(ALIVE)/aliveApp/Db/alive.db", "P=stxm:,RHOST=X.X.X.X")
iocInit
Starting iocInit
## EPICS R3.15.5
## EPICS Base built Jan 26 2017
reboot_restore: entry for file 'auto_positions.sav'
reboot_restore: Found filename 'auto_positions.sav' in restoreFileList.
*** restoring from '/opt/epics/synApps_5_8/ioc/stxm/iocBoot/iocLinux/autosave/auto_positions.sav' at initHookState 6 (before record/device init) ***
reboot_restore: done with file 'auto_positions.sav'
reboot_restore: entry for file 'auto_settings.sav'
reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
*** restoring from '/opt/epics/synApps_5_8/ioc/stxm/iocBoot/iocLinux/autosave/auto_settings.sav' at initHookState 6 (before record/device init) ***
reboot_restore: done with file 'auto_settings.sav'
recDynLinkOut: waiting for CA context
*** restoring from '/opt/epics/synApps_5_8/ioc/stxm/iocBoot/iocLinux/autosave/auto_settings.sav' at initHookState 7 (after record/device init) ***
recDynLinkOut: got CA context
auto_positions.sav: 0 of 0 PV's connected
saveData: message queue created
saveData:maxAllowedRetries = 10
saveData:retryWaitInSecs = 15
sevr=info Sequencer release 2.2.3, compiled Thu Jan 26 13:28:16 2017
sevr=info Spawning sequencer program "scanProgress", thread 0x249e420: "scanProgress"
sevr=info scanProgress[0]: all channels connected & received 1st monitor
sevr=info Spawning sequencer program "editSseq", thread 0x24b6610: "editSseq"
sevr=info editSseq[0]: all channels connected & received 1st monitor
sevr=minor ca_array_get_callback( typeToCA(type), count, var->chid, pvCaGetHandler, arg): Virtual circuit disconnect
# write all the PV names to a local file
dbl > dbl-all.txt
# Report  states of database CA links
dbcar(*,1)
CA links in all records
               stxm:pid_slow.INP  --> stxm:IP330_1                  (0, 0)
               stxm:pid_slow.OUTL --> stxm:DAC3_1                   (0, 0)
          stxm:pid_slowStop2.OUT  --> stxm:DAC3_1                   (0, 0)
 stxm:pid_slowOUT_tweak_down.INPB --> stxm:DAC3_1                   (0, 0)
 stxm:pid_slowOUT_tweak_down.OUT  --> stxm:DAC3_1                   (0, 0)
   stxm:pid_slowOUT_tweak_up.INPB --> stxm:DAC3_1                   (0, 0)
   stxm:pid_slowOUT_tweak_up.OUT  --> stxm:DAC3_1                   (0, 0)
      stxm:history1_PV1_DESC.DOL  --> .DESC                         (0, 0)
      stxm:history1_PV2_DESC.DOL  --> .DESC                         (0, 0)
      stxm:history1_PV3_DESC.DOL  --> .DESC                         (0, 0)
Total 270 CA links; 260 connected, 10 not connected.
    0 can't read, 0 can't write.  (0 disconnects, 0 writes prohibited)
# print the time our boot was finished
date
2017/02/03 08:57:44.475244
epics> scan1Menu.sav: 365 of 365 PV's connected
auto_settings.sav: 6 of 6 PV's connected
Re: Command omsMAXnetConfig not found Kevin Peterson
Prev: Re: edm, Fedora 25, and Wayland Andrew Johnson
Next: Re: Command omsMAXnetConfig not found Kevin Peterson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: Question : What kind of OPI is best? D Peter Siddons
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
