Hi Pierrick, I also had the problem with the fonts at EDM. What did the trick for me was: sudo xset fp+ /usr/share/X11/fonts/75dpi
Just the fonts.conf at /etc/X11/xorg.conf was not enough.
Cheers, Hugo
Certainly for medm the default fonts installed on RHEL 7 are not sufficient. The instructions on how to install additional fonts here is required:
http://aps.anl.gov/epics/extensions/medm/index.php
Perhaps edm needs the same packages?
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Pierrick Hanlet
Sent: Thursday, February 02, 2017 2:38 PM
To: Sinclair, John William; [email protected]
Subject: Re: problem compiling edm
Thank you John,
That did the trick.
Now I need to revisit the fonts issue. There's an old message of adding
Fonts.conf to /etc/X11/xorg.conf, but that doesn't appear to work with
this newer os.
Perhaps the problem is that I've not been able to find the "unscaled"
fonts. Any ideas?
Thanks again,
Pierrick
On 02/02/2017 04:12 PM, Sinclair, John William wrote:
> I believe I added the following to the makefile locally for newer versions of gcc:
> USR_CXXFLAGS += -fpermissive -Wno-narrowing -Wno-write-strings -Wno-unused-but-set-variable
> John Sinclair
> Sent: Thursday, February 02, 2017 9:16 AM
> To: [email protected]
> Subject: problem compiling edm
> I've a new pc on which I'm running Fedora release 25. I'm using base 3.15.5.
> I'm attempting to build edm, but whilst attempting to compile, I get:
> make[2]: Entering directory
> '/home/epics/epicsDEV/extensions/src/edm/lib/O.linux-x86_64'
> /usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX
> -Dlinux -O3 -g -Wall -DSINGLE_THREADED=1 -D__epics__=1
> -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I..
> -I../../../../include/edm/compiler/gcc
> -I../../../../include/edm/os/Linux -I../../../../include/edm -I/home/epics/epicsDEV/base/include/compiler/gcc
> -I/home/epics/epicsDEV/base/include/os/Linux
> -I/home/epics/epicsDEV/extensions/include -I../../util
> -I../../lib -I/usr/include -I/usr/include -c ../cursor.cc
> ../cursor.cc: In member function ‘void cursorClass::create(Display*, Window, Colormap)’:
> ../cursor.cc:82:50: error: narrowing conversion of ‘224’ from ‘int’ to ‘char’ inside { } [-Wnarrowing]
> 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
> ../cursor.cc:82:50: error: narrowing conversion of ‘224’ from ‘int’ to ‘char’ inside { } [-Wnarrowing] and many more lines of the same.
> I can't find this problem in tech-talk, nor with a web search. Has anyone run into this problem and if so, how did you resolve it?
> Many thanks,
> Pierrick
- problem compiling edm Pierrick Hanlet
- Re: problem compiling edm Pierrick Hanlet
- RE: problem compiling edm Mark Rivers
RE: problem compiling edm Sinclair, John William
<2017>
<2017>
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
