-----Original Message-----
Sent: Thursday, February 02, 2017 11:13 AM
To: 'Pierrick Hanlet'
Subject: RE: problem compiling edm
I believe I added the following to the makefile locally for newer versions of gcc:
USR_CXXFLAGS += -fpermissive -Wno-narrowing -Wno-write-strings -Wno-unused-but-set-variable
John Sinclair
From: [email protected] [mailto:[email protected]] On Behalf Of Pierrick Hanlet
Sent: Thursday, February 02, 2017 9:16 AM
To: [email protected]
Subject: problem compiling edm
I've a new pc on which I'm running Fedora release 25. I'm using base 3.15.5.
I'm attempting to build edm, but whilst attempting to compile, I get:
make[2]: Entering directory
'/home/epics/epicsDEV/extensions/src/edm/lib/O.linux-x86_64'
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX
-Dlinux -O3 -g -Wall -DSINGLE_THREADED=1 -D__epics__=1
-mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I..
-I../../../../include/edm/compiler/gcc
-I../../../../include/edm/os/Linux -I../../../../include/edm -I/home/epics/epicsDEV/base/include/compiler/gcc
-I/home/epics/epicsDEV/base/include/os/Linux
-I/home/epics/epicsDEV/extensions/include -I../../util
-I../../lib -I/usr/include -I/usr/include -c ../cursor.cc
../cursor.cc: In member function ‘void cursorClass::create(Display*, Window, Colormap)’:
../cursor.cc:82:50: error: narrowing conversion of ‘224’ from ‘int’ to ‘char’ inside { } [-Wnarrowing]
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
../cursor.cc:82:50: error: narrowing conversion of ‘224’ from ‘int’ to ‘char’ inside { } [-Wnarrowing] and many more lines of the same.
I can't find this problem in tech-talk, nor with a web search. Has anyone run into this problem and if so, how did you resolve it?
Many thanks,
Pierrick
- problem compiling edm Pierrick Hanlet
Re: problem compiling edm S. Banerian
Re: problem compiling edm Pierrick Hanlet
<2017>
<2017>
