I have a number of records over which I'm looping to assign values
to fields such as alarm limits.
The records and fields are assigned and then I assign a pointer to a
struct to each of these so
as to be able to loop over them.
However, I also have some records in this list which don't have
these fields; e.g. binaries and
so there is no connection the missing fields, but still to the PV.
So, within the loop, before writing
a seq_pvPut(), I'd like to check if there is a valid connection to
the field. I've tried
seq_pvConnected(ss_id,ndx+i) and seq_pvAssigned(ss_id,ndx+1), where
ndx is
the PV and ndx+1 is assigned to the different fields of that PV.
Any ideas?
Pierrick
"Whether you think you can or think you can't, either way, you are
correct" -- Henry Ford
_______________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+44-(0)1235-44-5550 (RAL)
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-888-0185/+44-(0)79-48-860-197 (US/UK mobile)
- Re: snl 2.2.4 question Benjamin Franksen
Re: How to write multi value in a caput message? Pearson, Matthew R.
pvaPy conda recipe? Lentz, Zachary L
<2017>
<2017>
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
