Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: How to write multi value in a caput message?
To: PilkyuJung <pilkyu@bmii.co.kr>
Cc: EPICS tech-talk <tech-talk@aps.anl.gov>
Date: Mon, 30 Jan 2017 21:39:53 -1000
I would use a genSub/aSub and a stringout.
HTH,
Maren
On Mon, Jan 30, 2017 at 9:23 PM, PilkyuJung <pilkyu@bmii.co.kr> wrote:
Hi all,
While I am working with EPICS, I got a problem. When I am using a SCPI command, I need to send two parameter in a message.
As you can see attached image, need 0~14 number and the other. So, now I used %s(in .proto file) and aao (record in .db file) like this.
setDIS{
out "DISP %s";
record(aao, "$(P)$(R)ST_x_DisPnl"){
field( DESC, "Display")
field( DTYP, "stream")
field( OUT, "@devddg.proto setDIS $(PORT1) $(A)")
That's it. However, I want to control with two parameter like this.
setDIS{
out "DISP %f, %f";
$ caput [PV name] value, value
So, please let me know how I can do.
Pilkyu Jung
How to write multi value in a caput message? PilkyuJung
Prev: How to write multi value in a caput message? PilkyuJung
Next: RE: How to write multi value in a caput message? Iain Marcuson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
ANJ, 14 Feb 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
